Results 1,671 to 1,680 of 1687
April 4th, 2025 10:02 AM #1671
Back in the 70's and 80's, the main failure points of window A/Cs were the metal base. They rusted through in a matter of a few years. The sweet spot was when they started transitioning to a plastic base. But eventually, in the name of efficiency and manufacturing cost-savings, they also started using materials that were relatively lighter and thinner (ie. coils, compressor), and then the trouble shifted to those parts.
- Nov 2019
- 1,406
April 4th, 2025 10:24 AM #1672
April 5th, 2025 03:05 PM #1673
Strike 2 for carrier i guess.
Ah i see, what model did you replaced it with ? Had good luck with the Hitachis(even though they have a reputation for moisture ingress issues) but it seems they made it worse lately atleast the specs on the nameplate suggests to be so.
- Nov 2019
- 1,406
April 5th, 2025 04:14 PM #1674Hitachi Inverter but na undersize ko (0.8HP), may issue lumabas na mag ice yung evaporator.
Need ko pa patuyuin/melt yung ice para bumalik sa dating lamig buga niya.
Yung ambient sensor kasi nasa malapit sa evaporator kaya akala niya malamig na room when this issue happen kaya pahinain/off niya compressor prematurely.
Hindi ko napaayos since sobra din kasi gumagamit chikiting ko ng AC kaya siguro ganyan behavior niya.
Lately, nag Panasonic Inverter WT na ako, no issue so far for 3 yrs ownership.
My Carrier before, less than 1 yr lumabas nung issue niya, kaya mas happy ako sa Panasonic Inverter ko ngayon.
Mas tahimik pa at closely similar yung noise level sa Split Type.
April 5th, 2025 11:45 PM #1675
Ung sa amin, nalalaman ko na nagyeyelo kapag humihina ang lamig. Naba block na kasi ang airflow. Kahit 3-4 times a month naglilinis ng filter, may alikabok pa rin na nakakalusot at kapag naipon doon na nagsisimula magyelo..usually 4-6mos.
April 6th, 2025 03:00 AM #1676
Un pala ung purpose ng isa pang sensor na nakabit deretso sa copper tube ng evaporator ng non-inverter panasonic namin - pang monitor ng frost buildup.
April 6th, 2025 07:12 AM #1677
April 6th, 2025 08:56 AM #1679
April 6th, 2025 09:14 AM #1680
AFAIK, Toshiba invented the inverter tech for HVACs in the 80s.
There was the Carrier-Toshiba partnership back in the late 90's to use some of those tech, but when Midea acquired some 80% stake of Toshiba in 2016, Carrier is now dealing with Midea. So if it gives anyone some comfort, both Carrier and Midea (including a smattering of other brands) utilizes some, if not most of Toshiba's inverter tech.
Are mandatory seatbelts, and minimum brightness standards for exterior lighting also woke elements?
Carbon fiber hood
