Agree. A 0.8 hp will work in my room but I'm getting 1 hp. A 1.5 hp will work in my living toom but I'm getting 2 hp.
Medyo masakit yung 1.5 to 2 hp because there's 10k difference between the two (since it's really closer to 1.33 hp than 1.5) but in the long run it's better in terms of consumption.
When computing for aircon size, consider all heat generators in the room - kitchen appliances (ref, stove, etc), TV, ambient sunlight from wall-to-ceiling windows or sliding doors, and of course extra people.
isa pa yan bro na winawalambahala ng mga nagbebenta ng AC sa ibang stores. pag na assess nila na .5hp AC lang kaya bilhin ng buyer, bebentahan parin knowing that it wont be enough for a 15 sq meter room with all family members in the same room. pag madalas ka dumadaan sa mga stores na ito, makaka tyempo ka talaga ng "sales talk" LOL
The best way to convince someone to get a window type air conditioner is to let them buy a split type air conditioner ...
Collateral damage from maintenance, leaks, repeated repairs, replacement (the chipping, masonry work, paintwork, floor & wall rehab, etc) can consume patience & tolerance. They downgrade to the real 'upgrade' of simplicity & practicality...the window.[emoji4]
Basta ako personal experience ko mas okay split type. We used to be all window-type before. Ngayon isa nalang yung window type namin, nasira pa. So now I have to buy 3 aircons instead of just 2. [emoji23]
Super mas tahimik when I switched from window to split. Also the aesthetics of the room, sobrang mas malinis tingnan.
Never naging bothersome for me maintenance. Tagal na rin naming naka-split type sa bahay and never ko naexperience yung mga hassle na sinasabi dito. Kaya nga kung first-hand experience ang best basis, ok na ok ako sa split type.
Mukhang me bad experience si travajante sa split type.. Well look for good installer and invest on good quality foam insulation sa piping.. Use 1" size pipe as drain pipe. Importante kung maiiwasan yung mahabang linya.. Tama ka mas malapit yung blower sa condenser mas maganda [emoji16]
They both have pros and cons. For me, split type is for aesthetics. It's just weird that before my split type would leak every six months while I never had a problem with window type even if I don't have it cleaned for years. What I don't like about window type is the hole in the wall (which is minor).
Nah, I just shared the pros, cons & measures needed. We even specify a minimum of 1.25" PPR drain, not blue. Splits are ideally installed along perimeter walls, where possible, to avoid lines running thru ceilings. If unavoidable, the insulated lines must be laid on gutter trays or thru pipes...I can go on & on.
Though I find joy in those of others, leak therapy isn't fun. Leaks can leave indelible scars, literally & figuratively.[emoji17]
Please don't get me wrong...I'm not anti-anything here. Just sharing to help prevent splitphobia.
