Results 791 to 800 of 1687
April 1st, 2018 11:16 AM #791
Can't remember Doc. It can be avoided since pwede "back to back" installation but I insisted they install the outdoor unit Doon sa Other side Since nakakasira ng aesthetic pag sa harap.
What I remembered is they brought 50 ft tubes and wirings, basta isang Roll and halos ubos yun rolyo
April 1st, 2018 11:24 AM #792
Yun din naiisip ko...
Plan is to start talking to Mitsubishi directly for their "multi split type" models... And the possibility to have them install a unit if I decide to buy overseas...
Gusto ko din sana Samsung since meron silang air-free mode and it works well with their robot vacuums...
Pero may 360 mode din naman Mitsubishi
Sent from my ASUS_Z017DA using Tapatalk
April 1st, 2018 11:26 AM #793
The gel are actially algae. To prevent them from building up, always use the self-cleaning function of your A/C, if available. Either that or leave it in low fan for 30 mins before totally shutting it off.
I can attest that this will prevent algae from blocking the airflow and drain. It also brought down our electrical consumption compared to when the same unit was suffocating in algae gel. During that time, I was having the A/C cleaned every 3-4 months. After religiously using the self-cleaning feature, 5 months out and it's still blowing strong air with barely noticeable reduction in performance.
April 1st, 2018 11:33 AM #794
April 1st, 2018 11:50 AM #795
April 1st, 2018 12:05 PM #796
April 1st, 2018 12:21 PM #797
Yes....but then there is added cost to do embedment the right way.
When embedded installs on new construction are requested, I would always pre-install the insulated lines in PVC pipes way before the wall plaster is applied. This will prevent unsightly old-new plaster joint cracks. Chipping thru existing painted walls to embed new lines will require masonry & paint work. Both will need lengthy cure time if you want top notch results. To prevent the said old-new plaster cracks that are bound to show months after, I'd clad the entire wall w/ cemboard for permanent seamlessness. All that will be added work & cost for the owner.
With external routing, the addition for the cover is minimal....& when trouble comes, it'll be a big relief for everyone.[emoji4]
April 1st, 2018 02:42 PM #798
April 2nd, 2018 06:57 AM #799
Kaya pag nasira un split type ko palitan ko na lang ng window type. Ok lang sa kin un ingay. Mas nakakainis un tulo. Hehehe!
Sent from my R7plusf using Tapatalk
April 2nd, 2018 07:57 AM #800
Windows, being DIYable, will get you freedom from the AC service people....much like freedom from car dealerships. Washes can be done yourself if you're handy. Some brands like Panasonic & Carrier share the same non-compact unit dimensions. To keep swaps quick, sticking w/ same brands & retaining sizes will save you the time, work, hassle & cost of cavity/blockout adjustment.[emoji4]
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
