Page 80 of 169 FirstFirst ... 307076777879808182838490130 ... LastLast
Results 791 to 800 of 1687
    #791
    well, if it can not be avoided...
    errr...magkano po siningil ng nag-kabit, por metro?
    Can't remember Doc. It can be avoided since pwede "back to back" installation but I insisted they install the outdoor unit Doon sa Other side Since nakakasira ng aesthetic pag sa harap.
    What I remembered is they brought 50 ft tubes and wirings, basta isang Roll and halos ubos yun rolyo
    Jul 2013
    #792
    I'd rather look for a nearby service center than SM or any other appliance center, and have them install it.
    This is much cheaper and maintenance​ should be fairly easy as you can call them anytime.
    The nearest service center around our place is Samsung. I'm a bit worried after reading some problems encountered with this brand. It's only a year old.
    Yun din naiisip ko...
    Plan is to start talking to Mitsubishi directly for their "multi split type" models... And the possibility to have them install a unit if I decide to buy overseas...
    Gusto ko din sana Samsung since meron silang air-free mode and it works well with their robot vacuums...
    Pero may 360 mode din naman Mitsubishi
    Sent from my ASUS_Z017DA using Tapatalk
    Jan 2009
    #793
    The gel are actially algae. To prevent them from building up, always use the self-cleaning function of your A/C, if available. Either that or leave it in low fan for 30 mins before totally shutting it off.
    I can attest that this will prevent algae from blocking the airflow and drain. It also brought down our electrical consumption compared to when the same unit was suffocating in algae gel. During that time, I was having the A/C cleaned every 3-4 months. After religiously using the self-cleaning feature, 5 months out and it's still blowing strong air with barely noticeable reduction in performance.
    #794
    ^+1. The frequency of cleaning will depend on location's pollution. Avoid having units facing roads or the dustiest side & direct sunlight.
    #795
    Just sharing, sir. Thanks.
    Note that free-install offers are contracted out. Discuss & insist with AC vendors & their contactors the detailed install specs & procedure. Chances are they'll request a lil add-on. Negotiate the cost, never compromise the specs. Some will contradict, sweet talk, convince & guarantee you with their 'experience' & 'standard' practice....the GOOD ones will agree with the sound request of proper install & materials.
    In a way we've been lucky. We wanted to hide the tubings, but the installer convinced us not to. With the same reasons you presented here.
    Sent from my SM-T705 using Tapatalk
    #796
    Easier installion for them.
    #797
    Yes....but then there is added cost to do embedment the right way.
    When embedded installs on new construction are requested, I would always pre-install the insulated lines in PVC pipes way before the wall plaster is applied. This will prevent unsightly old-new plaster joint cracks. Chipping thru existing painted walls to embed new lines will require masonry & paint work. Both will need lengthy cure time if you want top notch results. To prevent the said old-new plaster cracks that are bound to show months after, I'd clad the entire wall w/ cemboard for permanent seamlessness. All that will be added work & cost for the owner.
    With external routing, the addition for the cover is minimal....& when trouble comes, it'll be a big relief for everyone.[emoji4]
    Nov 2007
    #798
    Hehe....there will always be pros & cons. There are less noisy window units, though.
    If splits are desired, here are some tips:
    -Find the shortest route from room unit to the condensing for max efficiency. The condensing unit must be on a well-ventilated area & accessible to service. Though all-weather, delay rust by sticking on a sheet of extra rain protection, like polycarb or acrylic.
    -Insist on larger PPR drains beyond an inch in diameter with the least bends & distance to larger plumbing. P-traps are best installed on joint drains to prevent odor contamination. Common leaks are from clogging. Water & dirt will gel.
    -Install room units on perimeter walls to avoid routing lines thru ceiling. If ceiling routing is unavoidable, lay the properly insulated tubes & pipes on a sloped gutter tray all the way to the exterior outlet. This will handle condensation drips. Leaks & electricals can be a nightmare to sort.
    -Avoid cassettes when you can. Drain is by pump, not gravity. And, ceilings will tend to have blow marks & finger prints from service.
    -For easiest trouble shoots & swaps, opt for exposed lines over embedment. Just cover the unsightly w/ removable plastic or aluminum C-sections.
    True, proper installs, attention to detail, following standards & using reliable brands can give trouble-free split enjoyment for a long time. Taking measures to address known contraindications are just ounces of prevention that will outweigh the pounds of cure.
    Best tips for an AC drip-free home! Thanks!
    Jan 2008
    #799
    Kaya pag nasira un split type ko palitan ko na lang ng window type. Ok lang sa kin un ingay. Mas nakakainis un tulo. Hehehe!
    Sent from my R7plusf using Tapatalk
    #800
    Quote Originally Posted by kkreuk18 View Post
    Windows, being DIYable, will get you freedom from the AC service people....much like freedom from car dealerships. Washes can be done yourself if you're handy. Some brands like Panasonic & Carrier share the same non-compact unit dimensions. To keep swaps quick, sticking w/ same brands & retaining sizes will save you the time, work, hassle & cost of cavity/blockout adjustment.[emoji4]
Split Type Aircon: Which is best?
