Results 681 to 690 of 1687
- Aug 2016
- 194
June 5th, 2017 07:45 PM #681What would you guys recommend for a 21sqm office space. A window type or a split type? And what particular unit would you recommend?
Sent from my SM-N920S using Tsikot Forums mobile app
June 5th, 2017 08:03 PM #682
Window lang yan sobrang liit ng area.
- Jun 2005
- 3,774
June 5th, 2017 08:53 PM #683Our room is 19 sqm. I use 1.5hp inverter split type.
Will prolly replace to 2hp when it is beyond repair.
Get the window type if space permits. Problem with split types is the so called technicians dont install properly. In 6 months may leak ang fittings.
May style daw yan sabi ng rogue tech na nakausap ko. Higpit yung flare tapos luluwagan lang ng konting konti para unti unti sisingaw sakto sa 6month warranty ng installation
- Aug 2016
- 194
June 5th, 2017 11:41 PM #684For a 1 hp window type and a split type inverter.. how much savings should I be expecting each month? Would it be significant in about 2 to 3 years or the split types maintenace would just eat up the saved portion on the consumption?
- Jun 2005
- 3,774
June 5th, 2017 11:59 PM #685To give you an idea, i use our inverter aircon daily. 12 hours every weeknight and non-stop on weekends. Our electricity bill for the aircon is only 1,500 monthly (submetered so i know KWh used).
By contrast, a night's consumption of the non inverter window type in the other room is about 200 pesos.
For maintenance, window type cleaning costs only 500 pesos. Split types cost minimum 1,000. I have the inverter cleaned every 6 months.
In case of leaks, recharge of non inverter window type lowest i asked is 500 pesos while inverter split type is 3k, if you haggle.
June 6th, 2017 05:51 AM #686
- Apr 2012
- 3,469
June 10th, 2017 08:50 AM #687Hi, usually ba nasa 7,500 installin ng Inverter na split type? San merong medyo mas mura? Yung may cc installment sana
Sent from my LG-H818 using Tapatalk
June 10th, 2017 10:32 AM #688
Not sure if there are installers that accept credit cards, usually they are accredited contactors by aircon makers.
When i had my split type installed, i paid 11k for the installation since more than 10 meters of materials were used.
Sent from my ASUS_X00DDA using Tapatalk
- Apr 2012
- 3,469
June 10th, 2017 10:33 AM #689
- 54,205
June 10th, 2017 10:34 AM #690i would ask first, how much the charge would be, and have the cash ready. plus 50%, just in case.
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
