Results 701 to 710 of 1687
June 28th, 2017 10:57 PM #701
July 26th, 2017 07:09 AM #702
Carrier now has the best inverters? I didn't expect this at all lol.
The new inverter splits are the most expensive but they have the highest EERs?
CARRIER | X-Power Gold Inverter
- Apr 2012
- 3,469
July 26th, 2017 09:20 PM #703They have the most expensive units though.
Yung inverter na Samsung ko ayaw na mag ON since haven't used for 20 days na ata? Kasi lumipat ako ng tinutulugan na kwarto
Nung una laging naka ilaw yung timer indicator ko kahit di ko i set. Ngayon nawala na. Pero ayaw na mag ON
Sent from my LG-H818 using Tapatalk
July 26th, 2017 09:27 PM #704
baka your ground connection is floating?
July 26th, 2017 11:30 PM #705
In the end, it was down to Daikin vs Mitsubishi Electric.
And we chose Daikin, so far so good.
Thanks for all the inputs and feedback.
July 26th, 2017 11:54 PM #706
daikin? 1.5hp 24k?
September 13th, 2017 12:09 PM #707
Problema lang talaga sa split type ang daling masira ang panel board pagkamahal-mahal pa lalo na pag inverter.
September 13th, 2017 01:26 PM #708
September 13th, 2017 02:55 PM #709
September 13th, 2017 03:03 PM #710
moisture is the culprit.
soy-based wire insulation. 1. cheaper than the petroleum-based plastic insulation. 2....
BYD Philippines
