Page 2 of 9 FirstFirst 123456 ... LastLast
Results 21 to 40 of 168
    Sep 2013
    #21
    just wondering was this allowed by NTC that only all abs channels have had better receptions to other networks? para gusto ata ng abs na sila na lang ang mabuhay at kumita sa network industry. ito naman si NTC ay inutil din sa pamamalakad at implementations ng batas lalo na sa telcos issues. hmm magkano naman kaya ang tongpats nila?
    I'm from Tarlac, malinaw lahat ng ABS channels.
    Baka kailangan no outdoor antenna para makuha ibang channels tuktok mo Sa Manila. Siguro pwede yun nakikita ko sa CDR king na digital Tv antenna something.
    Sep 2013
    #23
    OT lang. nung nasa shanghai ako madaming akong nakita sa mall shops ( ala greenhills satin) na parang digital box hooked up sa small satellite disk as receiver. so yung mga programs sa HK, taiwan. s'pore etc. na naka-lock ay na-unlock nila so naging free channel lang tuloy. hehe
    #24
    Nilagay ko sa starex namin. Dito sa probins (Tarlac, Pangasinan), ABS channels lang (6 channels).
    In manila, 15 channels (incl. GMA, TV5 etc).
    As frequencies differ, you will need to re-scan whenever changing location.
    If you happen to be located in strong signal area, the supplied antenna can work indoors.
    I noticed some dead spots might occur near cell towers within 300 meters.
    Mar 2013
    #25
    How do you power the blackbox? Where can I buy the adaptors? Can I plug it in thr 12v car socket?
    Am thinking of placing this in my cars to help me deal with the traffic.
    Jan 2008
    #26
    Quote Originally Posted by kimbon View Post
    Kawawa naman ntc pinagbintangan agad ng conspiracy.... Abs cbn was the first to implement digital broadcast in preparation for the transition from analog to digital. Others follow suit and now on their test broadcast. Iim not sure but i think there is a 5 year transition plan to convert from analog to digital. So when that time comes vhf and uhf frequencies will be freed to be used for other purposes like free internet..
    Tv plus blackbox is a digital receiver designed to receive digital signal broadcast by tv stations. The IRR was released only last year that is why they can now sell the blackbox unlike before it was a promo at Ted failon show
    The tv plus should be able to receive all free tv broadcast plus some exclusive channels. You can buy other brand of digital receiver and should be able toreceive broadcast from 7, 2, 5, etc except for abs cbn exclusive channels like yey and cinemo
    Jan 2009
    #27
    Yea you can plug this thru the 12v. And this is being done
    #28
    mali ka dyan. hindi kasalanan ng abs kung sila pa lang ang naka upgrade to digital broadcasting. kasalanan na yan ng ibang channels bakit hindi pa sila nakapag-upgrade ng facilities nila with digital broadcasting equipment. all tv stations are required to upgrade to digital terrestrial tv (DTT) broadcast as per RA 3846. the original deadline for shifting from analog to digital tv broadcasting is December 31, 2015. however due to budgetary problems of other tv stations this deadline has been reset to the year 2020.
    the philippines has adapted the ISDB-T standard (japanese digital tv standard). kaya yung mga tinitinda na DVB-T (european digital tv standard) head units sa ebay will not work in the philippines although initially yun ang ginamit na standard for testing.
    Mar 2013
    #29
    Quote Originally Posted by smuiv View Post
    So what do i need to plug into the 12v and where can i buy it?
    Thanks!
    Dec 2007
    #30
    Unit is powered by 12V wall adaptor and in my case the installer just cut supplied wire and tapped it directly to a power supply (acc). Once the you start the engine, the unit is automatically powered on. And you can just turn off the unit if not in use, either via the remote controller or the unit's power button.
    Jun 2012
    #31
    Sa ncr, meron gma gma news tv, tv5, aksyon tv, at kung ano ano pa. Hindi lang abs. In fact mas malakas pa ang gma.
    At kahit lubak lubak ang daan, clear na clear pa rin yan
    Jan 2014
    #32
    Baka usual tv tuner gamit mo sir hindi black box na pang digital kasi sa pagkaka alam ko abs palang nag didigital broadcast. Wala pa ibang channels
    Dec 2014
    #33
    Meron na GMA: GMA (Ch. 12 on Skycable) and GMA News TV (Ch. 24 on Skycable).
    And I agree mas malakas ang GMA.
    Apr 2010
    #34
    Na try ko sa car using small power inverter 12v input 220v output as black box power supply it work using the supplied antenna. Hindi ko pa nasubukan while running on the road.
    Sep 2013
    #35
    Quote Originally Posted by luis_ View Post
    Quote Originally Posted by machine.pistol View Post
    *yebo, wow I'm impressed with those info's! tama ba understanding ko na sabi mo abs pa lang ang may digital brodcasting sa ngayon, hmm pero ano kaya itong nabasa ko galing kay machine.pistol as mentioned above na mayron na daw sa ibang networks maliban sa abs eh. Pls explain to me just like I'm a 5 yrs old child???
    OT -hwag nang mabad trip kung monday pa lang kaya smile lang tayo pag may free time para maging maganda ang ating buong linggo. Bwahaha
    #36
    trial broadcast pa lang ang channel 7.
    and as if naman tama ka dun sa earlier post mo. and just to remind you, here it is again:
    #37
    The signal in Pangasinan along TPLEX is good even at 100 kph. Signal starts to drop in Tarlac area (of TPLEX). Maybe Tarlac have different tower/frequency and re-scan is necessary(?).
    In Manila, the signal is good almost everywhere outdoors. Tall buildings and tunnels degrade the signal significantly.
    Sep 2013
    #38
    haha, sige na nga para sa ikakaunlad ng ating bansa mali na yung post ko 2 days ago pero ano kaya itong PM sa kin ng tsikot member na...extract from the source....
    "Net 25 with the help of GEMNET, had the first digital and full HD coverage of the 2010 Philippine elections via the ISDB-T system."
    here's the link for your quick reference
    Digital TV in the Philippines - Philippine Television Wiki
    wish ko lang na sana mali itong information sent sakin. Bwahaha
    #39
    Late na nga ang pinas, papunta pa lang ang mga broadcast networks sa hd samantalang sa iba like korea naka 4K na ang signal ng broadcasts nila.
    Dec 2014
    #40
    Papunta pa lang tayo sa digital from analog. Going digital does not mean going HD.
Question about ABS CBN TV PLUS (BLACK BOX)
