Results 61 to 70 of 92
- Nov 2009
- 3,509
January 28th, 2013 10:42 PM #61You will not be able to connect Globe's CPE since it is not a stand-alone router. The DSL port of the modem is for DSL only not for Ethernet hence they use different connector RJ11 for DSL, RJ45 for Ethernet.
If you can tweak the Globe modem, it may work on your PLDT line. All you need to know the DSL VCC settings(VPI.VCI) and WAN setting (bridge,PPoE,PPoA,DHCP, Static, etc). But before that, verify if you could access both modem. You need to know the setting from PLDT modem then copy it as a new setting profile on Globe's modem. Usually may password to change the settings of modem w/c comes in the firmware from the CPE vendor, but sometimes wala, default settings lang.
Or gawin mo na lang bridge yung Wifi ni Globe na ikaw lang ang nakakaalam ng iP block.. Set a static iP on PLDT's LAN then connect Globe modem to any of 1-4 LAN port. Your Wifi devices should be set on static iP's also.. Kung may guest ka na gusto maki-konek sa WiFi, bigay mo yung iP block..hehe It should work and will not cost you money.
February 5th, 2013 11:02 PM #62
just connect one LAN port of the globe router to your PLDT DSL modem LAN port
then connect your PC LAN to any of the globe routers 3 remaining LAN slot
turn on the wifi setting of the globe router & you should be abale to connect any wiifi enabled device to the globe routerLast edited by kisshmet; February 5th, 2013 at 11:06 PM.
February 7th, 2013 12:19 AM #63
February 7th, 2013 01:35 AM #64
Pldt my dsl gamit namin..plan 1299 ata pero nababagalan ako... Hay..
Sent from my GT-I9003 using Forum Runner
April 13th, 2013 03:59 PM #65
April 13th, 2013 04:14 PM #66
April 13th, 2013 04:17 PM #67
I requested for it on March then I totally forgot about it. When I called to follow up on Wednesday night, PLDT called the next day that it is ready for pick up na. I only opened the box today.
April 13th, 2013 04:25 PM #68
April 13th, 2013 11:00 PM #70
Bakit parang ang tagal naman niyan sir? Nakuha ko yung sa akin the day na pumunta ako sa branch nila. Hindi din pala nila kinuha yung old modem ko.
* ms. Cathy: nice one! Ganda namn ng modem mo. Kamusta yung signal coverage? Yung sa akin hindi umaabot sa ibang parts ng bahay. Ibang model pala yung binigay sa akin.
It may be variable speed I think. It's slowly being used on cars that either don't have an ICE, or...
A/c
