Page 1 of 2 12 LastLast
Results 1 to 20 of 92
    We used to have 2 DSL lines at home (PLDT and Globe). I use the PLDT line exclusively for my computer (LAN). The Globe DSL line is used for WIFI. The Globe DSL was been cut already and I was left with the router that they provided before. I still want to use WIFI at home and I am wondering if I could use the Globe provided router or is that locked for Globe only (?) If not, can someone please teach me how to set it up?
    I still want to be able to use my LAN for my computer at the same time have wifi. Please see the unit below (zyxel - pldt, blue - globe)
    Thanks in Advance!
    Connect the PLDT LAN port to the "DSL" port of the router.
    Connect the PC to any of the LAN ports of the Globe router.
    See if you can access the Globe router by typing 192.168.0.1 or 192.168.1.1 in your web browser.
    We'll see from there.
    The DSL port of the router is too small. That's so weird!
    But 1, 2, 3 and 4 fits naman.
    Now that I look at it, parang iba nga yung size. Odd. I've never seen that before.
    Is the DSL port of the Globe router the size of a telephone cable jack?
    In any case, kung iba yung size, you may need to buy your own wireless router.
    Globe wireless routers aren't so good anyway. We had one before that kept resetting (and thereby opening our WiFi to any random person in the vicinity).
    Just in case, there are good quality ones costing 1.5-2k, while the higher end ones will cost mga 4k.
    Edit: In relation to the different sized cable, can you count ilan yung metal strips doon sa connector ng wire that fits into the Globe router DSL port? Normally, a LAN cable will have 8 metal strips. Baka 4/6 lang yung doon sa globe.
    Quote Originally Posted by mda View Post
    Is the DSL port of the Globe router the size of a telephone cable jack?.
    The telephone jack fits perfectly
    It would be better just to buy your own wifi router.
    Personally I like TP-LINK brand because of affordable price and durability.
    Jun 2012
    I you want affordable, powerful, and decent wifi for home, or office, or the enterprise. Try the Ubiquiti products.
    Check these links.
    airMAX | Ubiquiti Networks, Inc.
    Unifi | Ubiquiti Networks, Inc.
    Check the Picostation M2 and the UNIFI
    These are locally available.
    In this case, you'll need to buy a separate router; the Globe router cannot be used because the DSL modem and the router are integrated into the Globe router.
    As I mentioned in my previous posts, you can get good-name-brand routers for as low as around 1.5kphp, with the more feature packed ones (and those with better wifi signals) going for almost 5k.
    Personally I'm using a Dlink DIR655 which can be had on sale now at one of the shops in gilmore I go to. No problems so far. I can PM you the link if you want (they have an online price list).
    Feb 2012
    I presume na yung router sa picture is the one from globe? Actually, the correct connection would be: from your PLDT ADSL modem connect the LAN RJ45 connector to any of the Ethernet ports 1, 2, 3 or 4 instead of directly to your PC's Ethernet port. Then connect your PC's LAN port to any of the vacant Ethernet port of the Globe router. Of course, you may need to configure some settings for you to access and/or secure your WiFi.
    You can probably connect your PLDT line directly to the Globe router instead of passing through the PLDT ADSL modem, but you may need to know the configuration settings.
    Quote Originally Posted by gearhead000 View Post
    Yes the one showing the ports is the globe router.
    So there'll be 2 LAN connected on my Globe router (PLDT and PC). I did that but I lost my connection e
    So even if I buy a new router I still need to know how to configure?
    Parang iba nga yung port. Bili ka na lang ng router, get the high end ones para mas reliable and mas malayo ang connection. I use linksys which costs 2800 ata yun. Kahit naglilinis ako ng sasakyan sa garahe, abot pa rin ang wifi. Hehe.
    Sent from my iPhone using Forum Runner
    Destroy your PLDT modem, then call them and ask for replacement then request for the modem/wifi router type. Wala ka na gastos anyway sabi mo pang kawarto LAN so pwede na yun
    Sent from my iPad using Forum Runner
    another brand thats underrated sa atin is Asus. maganda mga routers nila.
    Jul 2011
    nasira na dati ung modem ko from pldt. nung nag-request ako ng bagong modem sabi nila kailangan ko magbayad ng 2K for the new modem since lagpas na dun sa warranty period (2+ years na ata). buti nakuha sa konting pukpok at kutingting ung modem at napagana ko pa
    Almost 8 years old na PLDT modem ko. Never turned it off. Marupok na ata yung modems na issue ng PLDT
    Same here, 8 years, but it's turned off at night.
    If you are using plan 999 or higher, you can request them to get you a wifi modem. It's for free.
    Jan 2009
    CMIIW, you don't have to pay for anything to replace the CPE equipment provided by PLDT (ie. modem, modem+router, modem+router+wifi, etc.). AFAIK, these equipment are just leased to you and it is, though typically hidden, is included in your monthly bill. You didn't buy it and you don't own them, so if it breaks down years later, for as long as you still have a contract with the telco, they should replace it for free.
    Quote Originally Posted by ronki View Post
    Thanks for the info again. I called PLDT and I qualify for a free wifi modem. I only need to surrender my old modem. I'm a bit hesitant though because as you mentioned, the new pldt wifi modems aren't as sturdy as the units they gave out 8 years ago?
    Quote Originally Posted by s10pao View Post
    Sa office 3x na Ako nagpapalit and never Ako na charge...bigyan mo kasi kahit 200 yun Tao na pupunta para report niya na factory defect kahit winarak mo hence free
    Jul 2011
    hehe sige next time. customer fon rep lang kasi ung kausap ko kaya di ko masuhulan
How to Set up Wifi at Home
