Results 21 to 30 of 70
November 10th, 2002 10:04 PM #21
DSM619,
Hindi ata papasok ang 33" with the stock suspension. Pero kung sa 32" tataas na din siya.
20 degrees is more than enough for road use. Most cars have an apporach angle less than that.
Gen II Pajero pa din po dito sa Pilipinas. GEN III na yata iyang sa inyo.
November 10th, 2002 10:52 PM #22
ok tnx , check ko na lang availability sa size na maganda at kasya , di ko pa kasi na post pics eh . di pa ako naka baba sa barko .
November 10th, 2002 11:02 PM #23
Whatever you decide. Pls, DO NOT do like what this idiot did. :lol: :lol:
November 11th, 2002 12:08 AM #24
dsm619::: dude, those numbers are more or less irrelevant sa on road use coz more or less flat yung surface :D
lite::: nice one :D :D :D Photoshop!
November 11th, 2002 12:22 AM #25
Pajerokid
Unfortunately, that one was not photshopped. It actually happened and it was in the news few months ago.
November 11th, 2002 11:00 AM #26
pajerokid::: I did though of putting rubber pads sa ibabaw ng coil springs, may nagsabi sa akin baka daw ito matanggal if I use it on offroading pag sumobra ang extension ng springs.
Suspension upgrade for now, then aluminum bumpers with winch is my next target. :D
Oo nga pala, before I forget all coil springs ang suspension ng safari.
With regards dun sa angles, di ko pa nasusukat neither nababasa sa manual, hehehe.
November 11th, 2002 03:00 PM #27
lite::: ok. wow ang tiyaga nun! :mrgreen:
ungas::: o nga no! thats quite possible.
November 11th, 2002 03:12 PM #28
Litespeed::: Departure angle nyan mukhang zero (0) na, hehehe. Buti di nagputukan mga tires nun?
November 11th, 2002 05:40 PM #29
ungas:: ..... on the subject of spring pads, if you extend the springs too much, eh di may possibility na matanggal na rin yung springs mismo diba :?: so i guess medyo ok pa rin to use the pads but kelangan siguro ingat lang :mrgreen:
- 238
November 11th, 2002 06:50 PM #30Originally Posted by pajerokid
Hey, get down from the vehicle right before the attempt. Assess, then
decide.
Suspension lifts are mostly decided by the tire size you want.
33" on a Patrol will make it streetable and light to moderate offroad capable. A 2" lift is enough to fit these donuts.
However, the Patrol can possibly go to 35 or 36 inch tire diameters. That is because of the availability of aftermarket suspensions up to 8" lift and lower r & P / t case gears.
Edsa is about 24kms long. So, 15b / 24 is approx 625m per km?
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
