Results 41 to 45 of 45
September 21st, 2005 02:35 AM #41
Originally Posted by vwturbo
kung ikaw nga yan.. yes, nasa US na kami, nandito kami sa Houston (Texas) pare. eto email address ko: mgbrillo*gmail.com
To moderator.. pasensya na po.. na-miss ko lang tong tropa ko.. nagulat ako that he's also a member here
Keep in touch bro.
Mark Brillo
September 21st, 2005 08:59 AM #42
Originally Posted by mazdamazda
September 21st, 2005 09:04 AM #43
Originally Posted by graphire
Originally Posted by mgbrillo
September 21st, 2005 12:07 PM #44
I believe in US cars this is required for the car to start. Pag AT naman you have to press the brake.
Prevent accidental jerk siguro.
September 21st, 2005 04:11 PM #45
Actually that is perfectly ok for newer cars, walang masama kung ritually mo gagawin or if you are in a hurry you can just fire away,...
pag turn mo ng key sa accessory position mag li-light up na parang christmas tree yung front gauges mo,... some cars will run their diagnostics to search for stored error codes.. Cel(check engine light)/Mil(malfunction indicator light), or service maintenance required indicator.... with some cars you can reset the throttle body adaptation to factory settings by leaving the acc on, opening the hood and letting throttle plate actuator cycle for 1 min... some you can reset the radio from safe mode by leaving the keys on...
sorry mod...
Anong size need nyo? May nabibili ako online from lazada. Baka malapit lang sa inyo yong store...
Finding the Best Tire for You
