Page 1 of 3 123 LastLast
Results 1 to 20 of 45
    Jan 2004
    this may sound odd.. dumb (?) [wag naman sana, nagtatanong lang po]
    i was used to starting my car with a little delay.. like.. you insert the key, twist it once, then lights, and everything (electrical) goes up, then maybe about 4-6 seconds, i start ignition.. one person told me that this is no good.. di naman daw diesel ang sasakyan so... so anyway.. is this bad? with the pause before ignition? or talagang kelangan na start agad (turning the key to I then II immediately?
    in our 323, when you put the key in the start position, it will beep for a few seconds. naturally I don't start the engine until the beeping stops.
    Aug 2003
    Quote Originally Posted by mazdamazda
    bro bakit yung 323 ko wala na kong beep naririnig. as soon as i position key to II i'll hear hums and lights on indicators sa dash. I dont start it right away... minsan kasi parang hirap mag-crank pag start agad. I dont know advantages of starting right away and delaying it. others.. pls enlighten. thanks.
    Aug 2003
    pausing for a few seconds lets the fuel pump pressurize the fuel system. in my experience, not pausing may cause harder starting.
    Quote Originally Posted by orly_andico
    Same here, my car hardstarts if i crank it right away sa unang start of the day. If I leave it on "on" for a couple of secs, it starts easier.
    Quote Originally Posted by theveed
    baligtad naman sa galant ko.pag pinatapos ko ang mga beeping sounds,...hirap siya mag start.pagka on dapat start ko agad...
    baket kaya ganun?
    Quote Originally Posted by graphire
    carb or fuel-injected ba yung sa iyo?
    no problem with starting with our 323 until now.
    btw, sa manual ng 323 - nakalagay dun na dapat naka depress ang clutch while starting?
    Aug 2003
    carb 323 akin. full depress ba ng clutch? i just depress a little gas pag start e. so pano yun, pwede sabay? whats d reason kaya for the clutch depress? la na kasi manual 323 ko e. thanks.
    Jan 2004
    in my car... beeping starts kasi it checks all the other thingys in sensors, airbags, stuffs like that, then beeps (lastly) that the seatbelts are not fastened.. i dunno if there's a difference in pausing and just starting it rightaway.. i start ignition when the beeping stops..
    Jul 2003
    hehehe ang galing nito.. i sometimes do that para lang macheck ko kung off ba aircon ko and everything bago ko start talaga...
    Jan 2004
    so is there any 'bad' effect when pausing before ignition?
    doesn't make a difference. parang *** yan...either isaksak mo at i-start kaagad, o medyo i-tease mo muna ng konti...ganun pa rin yung outcome :lol:
    Jan 2004
    I don't see any problem with either method unless it is strictly specified in the operating manual. Kasi pag-start naman papatayin halos lahat ng devices sa current draw ng starter.
    basta ako, the following procedures work:
    a) Put in the key
    b) Take a deep breath three times.
    c) Close eyes for around 5 seconds.
    d) Turn on the ignition.
    wala namang adverse effects sa oto ko. although after i do step d, medyo inaantok and relaxed na relaxed ako....
    Aug 2005
    Quote Originally Posted by happy_gilmore
    a) Put in the key
    maganda suggestion ni gilmore
    my car kasi carb sakin push ko gas pedal once full mga 1 or .5 sec (kasi nasa manual ko)
    hindi dapat eh force mo ng 10-15 seconds pra pag start lng sa car mo kasi mag overheat at masira ang ignition coil . (nasa manual din)
    just sit back and relax. tapos broom broom broom kana.
    hinihintay kong mawala yung airbag light or the key bonger stops hehe
    Dec 2003
    i wait till the last of the warning lights disappear, last one is the CAT, before starting the engine.
    pag nawala na yng check engine light...usually 2-3 sec. pag on ng switch cya nawawala, ewan ko bat pag dire-drecho ko start antagal mag crank...
    Jan 2004
    sabi kasi nung isang nakakita sa akin nung nag start ako ng auto... eh baka .. masusunog daw yung sa may ignition part??? kaya ko tuloy natanong ito eh.. di naman daw diesel ang auto so bakit kelangan painitin? the kelan ba mag engage yung mechanism sa pag start? once ur on "I" position? o pag nag ignition ka mismo?
    Jun 2005
    Quote Originally Posted by mgbrillo
    sabi kasi nung isang nakakita sa akin nung nag start ako ng auto... eh baka .. masusunog daw yung sa may ignition part??? . . . . .
    yup, meron possibility masunog yung ignition coil mo (kasi mag o-overheat kung matagal). On current gas engines, you only need time to prime the fuel system (i.e. pressurize your fuel rail), and during this time, your ECU does a quick diagnostic check.
whats the right way to start ur car?
