Results 21 to 30 of 45
September 14th, 2005 09:43 PM #21
Originally Posted by theveed
baligtad naman sa galant ko.pag pinatapos ko ang mga beeping sounds,...hirap siya mag start.pagka on dapat start ko agad...
baket kaya ganun?
September 14th, 2005 10:07 PM #22
hehe akin din di ko alam kung baket ganun, tinanong ko sa casa wala naman binigay na sagot.
September 14th, 2005 10:16 PM #23
Me, I wait for orange light to turn off,kase its checking daw or diagnostic check sa car mo to make sure na everythings well before mo iharurot yung car....hehehehehe...2 to 3 sec lang naman....
Toyota is my choice
- Aug 2005
- 2,063
September 15th, 2005 05:18 AM #24Originally Posted by happy_gilmore
my car kasi carb sakin push ko gas pedal once full mga 1 or .5 sec (kasi nasa manual ko)
hindi dapat eh force mo ng 10-15 seconds pra pag start lng sa car mo kasi mag overheat at masira ang ignition coil. (nasa manual din)
just sit back and relax. tapos broom broom broom kana.
September 15th, 2005 11:29 AM #25
sa diesel kong sasakyan, specified sa manual na hintay ko raw muna mamatay yong isang particular na ilaw sa instrument panel bago ko start...so yon ang ginagawa ko.
sa gas ko naman na tsikot, wala naman sinabi sa manual pero habit ko ay wait around 2 secs or until mamatay yong mga instrument lights saka ko start. never had problems yet for the past few years..so i must be doing something right...
September 15th, 2005 11:42 AM #26
i usually start my car in the morning with the ignition key only w/o pressing the gas pedal. then wait for my temp to go up 1/4 (approx. 2 min) then ready to go
September 15th, 2005 12:11 PM #27
here's mine:
1. press gas pedal to the floor once
2. put in the key
3. turn ignition key to on
4. pause for 5 to 8 secs (praying - "Lord sana magstart, guide me along the way at wag po sana tumirik :angel: )
5. press gas pedal ng konti then switch to start... broooommmm
here's a useful link that you read re: proper way to start your car
http://www.securitydriver.com/aic/st...rticle-26.html
September 15th, 2005 12:23 PM #28
hintay ko mawala yung CEL...sa isa naman yung ilaw ng airbag...di na ako umaapak sa gas pedal...nasa brake pedal naman kasi paa ko kapag AT ang tsikot...
noong gamit ko eh carb konting apak muna sa gas pedal bago ko pihitin susi...
couch potato
- May 2005
- 1,384
September 15th, 2005 12:42 PM #29graphire: good read .. pasting parts which i found informative ..
Fuel-injected cars are computer controlled, so you shouldn't touch the gas pedal at all. "In fact," says Mike Michels of the Toyota Motor Company of America, "hitting the gas only confuses the computer."
Finally, turn the key. Don't press or pump the gas pedal while turning the key in a fuel- injected car. In a carbureted car, press the accelerator down to one-quarter to one half of the way. Release the gas immediately when the car starts.
If the engine should flood press the accelerator down all the way to the floor and hold it. On a fuel- injected car this sends a message to the computer that the car is flooded, and the computer in turn shuts off all fuel. On a carbureted car, pressing the accelerator all the way to the floor allows more air to pass through the manifold, evaporating the excess gas. Don't pump the accelerator while you crank the engine.
September 16th, 2005 01:58 AM #30
carb yung sa akin dati..
ngayon automatic/fuel injected na..
so.. need to read the manuals.. hehehehe.. baka may specifics on my car..
what im doing right now is pause for abt 2 to 3 sec as mentioned here.. then brooom!
(also with the prayers na sana walang mangyaring di kanais-nais while driving and you get home safely).
Yes kasi adjusted na nila yun binayaran mo initially to reflect yun correct plate ending mo, that's...
1st LTO renewal after 3 yr registration
