Page 8 of 9 FirstFirst ... 456789 LastLast
Results 71 to 80 of 90
    May 2017
    #71
    i read somewhere, that we can overinflate it by 10% over the recommended psi, as long as we do not go over the tire's maximum psi.
    i have been doing it for many years now, and the tires do not seem to complain by showing abnormal tire wear pattern.
    n.b. my tires are factory spec.
    Nabasa ko lang sa internet na during hot summer, halos nag-aadd ng +2 psi sa gulong mo ang hot temperature lalo na kapag nasa expressway ka. Kapag nagpapahinga na ang sasakyan mo e mawawala na yung +2 psi sa gulong. Do you think this is true?
    Sep 2005
    #72
    As the molecules heat and move faster, they are moving apart. So air, like most other substances, expands when heated and contracts when cooled. Because there is more space between the molecules, the air is less dense than the surrounding matter and the hot air floats upward.
    May 2017
    #73
    Thank for the explanation bro!
    #74
    sounds logical.
    but i do not go thru the ritual.
    i just put in, the door pillar spec + 5 to 10%.
    over the many years, i have not noticed any negative effects thereof.
    May 2017
    #75
    sounds logical.
    I'm also leaning in this view, the maximum psi is already written on the tire codes at the side of the tire. I also have not seen any of our tires having a wornout tire-thread at the middle part of the tire which is an indicator of overinflation.
    Jul 2013
    #76
    Mukang may umabsent sa HS chem class? That is basic gas law. Guy Lussac Law. Pressure increases as temperature increase assuming same volume (tires can expand but only up to a certain point).
    If you have TPMS, you would havfe observed that already. With ordinary air, I observe as much as 5psi increase from my garage to SLEX running at speed limit. With nitrogen, the increase is only around 2psi.
    #77
    Totoo ba ito? Or baka sa wear and tear lang naman as time goes on kaya nasisira stablizer link.
    Kahit naman siguro underinflated nasisira din stablizer link...
    pagover inflated ang tires suspension masira. pag under naman, mas malaki possibility yun sidewall ng tires.
    btw ginagawa ko pag nag inflate ng gulong, as much as possible gabi or maagang maaga; or pag mainit talaga panahon, gas out ko muna tires ko for 30 seconds, bago ko karagahan ng hangin. so far effective itong style ko and napansin ko mas consistent ang psi ng 4 tires.
    Feb 2018
    #78
    Also, wheels are hot during use due to friction + road surface temperature. Pag napahinga na, bababa talaga pressure.
    #79
    Quote Originally Posted by Lew_Alcindor View Post
    it takes extra effort to keep looking awake during the 1 pm chemistry lecture.
    car manufacturers and tire manufacturers already put into the equation, the expected air expansion when the tire heats up with use, and air contraction during the cool-down period. we but have to follow the prescribed psi.
    Jan 2009
    #80
    ^ I agree on this.
    The recommended pressure on the door jamb already takes into consideration that the mass of car owners will just be using regular air to pressurize their tires. That also means that air expansion has also been factored in. If this is not the case, you would be seeing an alarming cases of tires exploding on the road.
    Contrary to popular belief, tires are less likely to explode when slightly over-inflated. A tire's structural integrity relies on the air pressure inside it. Under-inflated tires will cause excessive flexing and stress that will eventually lead to overheating. In which case, this will cause the tire to disintegrate while in operation... sometimes catastrophically.
Tyre pressure
