Results 71 to 80 of 90
- May 2017
- 2,099
March 10th, 2020 09:41 AM #71
March 10th, 2020 10:00 AM #72
As the molecules heat and move faster, they are moving apart. So air, like most other substances, expands when heated and contracts when cooled. Because there is more space between the molecules, the air is less dense than the surrounding matter and the hot air floats upward.
- May 2017
- 2,099
- 52,731
March 10th, 2020 10:05 AM #74
- May 2017
- 2,099
March 10th, 2020 10:12 AM #75
- Jul 2013
- 2,450
March 10th, 2020 10:18 AM #76Mukang may umabsent sa HS chem class? That is basic gas law. Guy Lussac Law. Pressure increases as temperature increase assuming same volume (tires can expand but only up to a certain point).
If you have TPMS, you would havfe observed that already. With ordinary air, I observe as much as 5psi increase from my garage to SLEX running at speed limit. With nitrogen, the increase is only around 2psi.
March 10th, 2020 10:30 AM #77
pagover inflated ang tires suspension masira. pag under naman, mas malaki possibility yun sidewall ng tires.
btw ginagawa ko pag nag inflate ng gulong, as much as possible gabi or maagang maaga; or pag mainit talaga panahon, gas out ko muna tires ko for 30 seconds, bago ko karagahan ng hangin. so far effective itong style ko and napansin ko mas consistent ang psi ng 4 tires.
March 10th, 2020 10:35 AM #78
- 52,731
March 10th, 2020 10:47 AM #79it takes extra effort to keep looking awake during the 1 pm chemistry lecture.
car manufacturers and tire manufacturers already put into the equation, the expected air expansion when the tire heats up with use, and air contraction during the cool-down period. we but have to follow the prescribed psi.Last edited by dr. d; March 10th, 2020 at 10:51 AM.
March 10th, 2020 12:22 PM #80
^ I agree on this.
The recommended pressure on the door jamb already takes into consideration that the mass of car owners will just be using regular air to pressurize their tires. That also means that air expansion has also been factored in. If this is not the case, you would be seeing an alarming cases of tires exploding on the road.
Contrary to popular belief, tires are less likely to explode when slightly over-inflated. A tire's structural integrity relies on the air pressure inside it. Under-inflated tires will cause excessive flexing and stress that will eventually lead to overheating. In which case, this will cause the tire to disintegrate while in operation... sometimes catastrophically.
Monk-owned R53
