Page 1 of 2 12 LastLast
Results 1 to 20 of 90
    Quote Originally Posted by Darc View Post
    Ano po correct/recommended tyre pressure ng vehicle ko?
    Vechicle: Toyota Fortuner 2015 (2" lifted)
    Tyres: Monsta AT 265/70R17
    Wheels: Fuel Vapor 17"
    Newly changed po yung wheels ang tyres ko 1 week ago. Hindi na ako sure if kailangan ko pa sundin yung nasa door panel ko (30 PSI) - ganito rin sabi ng shop kung saan ko binili yung wheels/tyres, 30 to 32psi lang daw.
    Pagka-30 kasi feeling ko masyadong yupi yung gulong.
    i read somewhere, that we can overinflate it by 10% over the recommended psi, as long as we do not go over the tire's maximum psi.
    i have been doing it for many years now, and the tires do not seem to complain by showing abnormal tire wear pattern.
    n.b. my tires are factory spec.
    ako 40 sa likod, 35 sa harap. Ako lang nag-analyze ganito setup. Naisip ko kasi yung gulong ng formula 1 racing malaki sa likod kaya ganun ginawa ko sa hangin.
    tapos pakita ko sa vulcanizing if maganda kain ng gulong.
    Mar 2004
    It's the suspension that will complain ... usually the stabilizer link goes first ...
    depende siguro sa kotse, sa nagmamaneho, at saan minamaneho.
    my innova has over 140K km on the odometer, and except for the shocks, the suspension is still the one that came with the car, from the factory.
    it's a bit noisy now, but still serviceable.
    May 2017
    Totoo ba ito? Or baka sa wear and tear lang naman as time goes on kaya nasisira stablizer link.
    Kahit naman siguro underinflated nasisira din stablizer link...
    pagover inflated ang tires suspension masira. pag under naman, mas malaki possibility yun sidewall ng tires.
    btw ginagawa ko pag nag inflate ng gulong, as much as possible gabi or maagang maaga; or pag mainit talaga panahon, gas out ko muna tires ko for 30 seconds, bago ko karagahan ng hangin. so far effective itong style ko and napansin ko mas consistent ang psi ng 4 tires.
    May 2017
    Sir can you please explain more, I want to learn bakit nakakasira sa suspension ang overinflated tires thank you!
    eto nalang bro
    What Happens if I Overinflate My Tires? overinflation tir...
    When the tire is overly-inflated the sidewalls become harder, and instead of absorbing the road bumps and shocks, they are transferred straight through to the vehicle’s suspension. This can result in a harsher ride, as well as increased road noise from the tires. In severe cases, when dealing with older or severely overinflated tires, the tire’s sidewall may even be put at risk to blowing out due to the increased pressure.
    May 2017
    Thanks ninjababez!
    So harder tires transfer additional stress of hitting road bumps more often to the suspension, aside from having a bouncy road travel.
    During floods and rainy season din pala, not advisable to have overinflated tires as there would be less grip with the ground.
    Dec 2023
    Hi ninja,
    I chose my handle for good reason: Back in the states my hands are tied trying to dismantle myths regarding tire care.
    And one of them is overinflation! Americans can't seem to get enough air in their tires. Many of my fellow Yanks insist on keeping tires pressurized to the maximum load pressure molded into the sidewall, and consider the vehicle spec pressures "too low", and "mushy" by comparison.
    I tell them, try running 45-50 psi on a Tacoma or Hilux equivalent on rainy mountain roads where my wife's family lives in Benguet, and see how far they get.
    But hey, it's their ride, and "none of my biz".
    I'm in regular contact with, of all people, a re'tire'd(!) engineer for the U.S. branch of Continental Tire Co. I studied his website, and paid attention to what he taught me in our e-mail correspondence. He is a treasured car care resource.
    May 2017
    Nabasa ko lang sa internet na during hot summer, halos nag-aadd ng +2 psi sa gulong mo ang hot temperature lalo na kapag nasa expressway ka. Kapag nagpapahinga na ang sasakyan mo e mawawala na yung +2 psi sa gulong. Do you think this is true?
    Sep 2005
    As the molecules heat and move faster, they are moving apart. So air, like most other substances, expands when heated and contracts when cooled. Because there is more space between the molecules, the air is less dense than the surrounding matter and the hot air floats upward.
    May 2017
    Thank for the explanation bro!
    Feb 2018
    Also, wheels are hot during use due to friction + road surface temperature. Pag napahinga na, bababa talaga pressure.
    sounds logical.
    but i do not go thru the ritual.
    i just put in, the door pillar spec + 5 to 10%.
    over the many years, i have not noticed any negative effects thereof.
    May 2017
    sounds logical.
    I'm also leaning in this view, the maximum psi is already written on the tire codes at the side of the tire. I also have not seen any of our tires having a wornout tire-thread at the middle part of the tire which is an indicator of overinflation.
    Jul 2013
    Mukang may umabsent sa HS chem class? That is basic gas law. Guy Lussac Law. Pressure increases as temperature increase assuming same volume (tires can expand but only up to a certain point).
    If you have TPMS, you would havfe observed that already. With ordinary air, I observe as much as 5psi increase from my garage to SLEX running at speed limit. With nitrogen, the increase is only around 2psi.
    Quote Originally Posted by Lew_Alcindor View Post
    it takes extra effort to keep looking awake during the 1 pm chemistry lecture.
    car manufacturers and tire manufacturers already put into the equation, the expected air expansion when the tire heats up with use, and air contraction during the cool-down period. we but have to follow the prescribed psi.
    Jan 2009
    ^ I agree on this.
    The recommended pressure on the door jamb already takes into consideration that the mass of car owners will just be using regular air to pressurize their tires. That also means that air expansion has also been factored in. If this is not the case, you would be seeing an alarming cases of tires exploding on the road.
    Contrary to popular belief, tires are less likely to explode when slightly over-inflated. A tire's structural integrity relies on the air pressure inside it. Under-inflated tires will cause excessive flexing and stress that will eventually lead to overheating. In which case, this will cause the tire to disintegrate while in operation... sometimes catastrophically.
    May 2017
    kaya mas gusto na namin yung mga tire manufacturers coming from Indonesia and Thailand kaysa sa China. At least it is already in their experience what is happening on their products right before their eyes especially during summer
Tyre pressure
