btw word of caution use a smaller size extractor, i center punch nyo muna yung putol na bolt para naka center yung extractor, use a drill with reverse and variable speed...set muna sa slowest speed "push hard" enough para kumagat ang extractor and apply pulse power to the drill set on REVERSE.
key word PATIENCE....lalabasan ...este lalabas din yan....
walang sinabi yung mga case ninyo .... yung sa akin the distributor adjustment bolt ang naputol ko....I have to remove the distributor (along with its "gear")...then I have the risk pa to have metal shavings drop into the engine....whew....PATIENCE lang talaga at pamunas ... para pagnilabasan (este) paglumabas yung bolt e hindi mahulog inside the engine.
GOOD LUCK!!!
