Results 1 to 10 of 17
- Feb 2005
- 64
October 13th, 2005 03:07 PM #1Guys, need your inputs.
Naputol un head ng isang screw ko that holds the plate number sa front bumper. Nastuck ngayon un rest ng screw dun sa thread hole. I tried to forcibly "unscrew" it by spraying it with penetrating oil and using pliers but to no avail. Any suggestions what to do or where to go? Hindi ko kse maikabit ngayon un plate dhil isang screw lng maghold baka malaglag pa. Appreciate any helpful info.
Thanks!
October 13th, 2005 03:11 PM #2
go to your nearest friendly neighborhood DIY hardware and get yourself a set of screw extractor. or you can use a hand drill with a small drill bit to drill it out.
couch potato
- May 2005
- 1,384
October 13th, 2005 03:19 PM #4
e anu naman recomend nyo para maalis naman ung naputol kong screw sa a/t oil pan.... my fault, i used my heavy ratchet and i thought its not tight...but im wrong...
ayun tangal ung ulo ng screw, naiwan ung body...anu pa suggesstion nyo without removing the whole tranny and bring it to the machine shop and suggestion ni sir bluebimmer?
liit lang bolt na un #10 ung socket na ginamit ko.
October 13th, 2005 03:36 PM #7
ask ko lang ano ang "lay-man's term" ng screw-extractor na un..ba mayroon sa hardware namin at mapakuha ko na....
October 13th, 2005 03:37 PM #8
try mo kya kumuha ng same size na screw tapos pai-spot mo sa welding shop.
kpag medyo malamig na, pihitin mo na.
October 13th, 2005 03:39 PM #9
nga pala, lubog ung body ng screw ..kaya out ang option for spot weld.
October 13th, 2005 03:53 PM #10
Actually you can try to punch a slot onto the remaining part of the screw ala "minus" tapos use a smaller sized screwdriver to unscrew it. Ingat lang baka magasgas yung bumper.
