Results 11 to 17 of 17
October 13th, 2005 04:21 PM #11
Sabihin mo sa hardware o auto parts store "easy-out". Yan yung pangtanggal nyan. Yan ang local linggo for screw extractor. You will need a drill for that
October 13th, 2005 05:35 PM #12Originally Posted by blve_ice
which can be purchased at a local harware.
- Feb 2005
- 64
October 13th, 2005 09:09 PM #14Originally Posted by BlueBimmer
- Feb 2005
- 64
BANNED BANNED BANNED
- 3,790
October 13th, 2005 11:03 PM #16btw word of caution use a smaller size extractor, i center punch nyo muna yung putol na bolt para naka center yung extractor, use a drill with reverse and variable speed...set muna sa slowest speed "push hard" enough para kumagat ang extractor and apply pulse power to the drill set on REVERSE.
key word PATIENCE....lalabasan ...este lalabas din yan....
walang sinabi yung mga case ninyo .... yung sa akin the distributor adjustment bolt ang naputol ko....I have to remove the distributor (along with its "gear")...then I have the risk pa to have metal shavings drop into the engine....whew....PATIENCE lang talaga at pamunas ... para pagnilabasan (este) paglumabas yung bolt e hindi mahulog inside the engine.
GOOD LUCK!!!
- Feb 2005
- 64
October 14th, 2005 12:47 AM #17Originally Posted by wildthing
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
