Results 1 to 17 of 17
    Feb 2005
    Guys, need your inputs.
    Naputol un head ng isang screw ko that holds the plate number sa front bumper. Nastuck ngayon un rest ng screw dun sa thread hole. I tried to forcibly "unscrew" it by spraying it with penetrating oil and using pliers but to no avail. Any suggestions what to do or where to go? Hindi ko kse maikabit ngayon un plate dhil isang screw lng maghold baka malaglag pa. Appreciate any helpful info.
    Thanks!
    Dec 2003
    go to your nearest friendly neighborhood DIY hardware and get yourself a set of screw extractor. or you can use a hand drill with a small drill bit to drill it out.
    May 2005
    you can change your bumper .. hehe ..
  4. #4
    e anu naman recomend nyo para maalis naman ung naputol kong screw sa a/t oil pan.... my fault, i used my heavy ratchet and i thought its not tight...but im wrong...
    ayun tangal ung ulo ng screw, naiwan ung body...anu pa suggesstion nyo without removing the whole tranny and bring it to the machine shop and suggestion ni sir bluebimmer?
    liit lang bolt na un #10 ung socket na ginamit ko.
    yung suggestion ni BB lang ang tamang gawin actually.
  6. #6
    *edit*
    double post....pwede bang maalis na itong isa?
  7. #7
    ask ko lang ano ang "lay-man's term" ng screw-extractor na un..ba mayroon sa hardware namin at mapakuha ko na....
    try mo kya kumuha ng same size na screw tapos pai-spot mo sa welding shop.
    kpag medyo malamig na, pihitin mo na.
  9. #9
    nga pala, lubog ung body ng screw ..kaya out ang option for spot weld.
    Actually you can try to punch a slot onto the remaining part of the screw ala "minus" tapos use a smaller sized screwdriver to unscrew it. Ingat lang baka magasgas yung bumper.
    Feb 2005
    Sabihin mo sa hardware o auto parts store "easy-out". Yan yung pangtanggal nyan. Yan ang local linggo for screw extractor. You will need a drill for that
    Aug 2005
    Quote Originally Posted by blve_ice
    Thanks!
    You'll be needing a drill and a set of screw extrator (see diagram)
    which can be purchased at a local harware.
    Jun 2005
    Quote Originally Posted by mrpink
    Or the car . . .he he
    Feb 2005
    Quote Originally Posted by BlueBimmer
    Tnx very much Sir BB! I'll get myself a set of that tom and try.
    Feb 2005
    Quote Originally Posted by leinahtan
    Tnx din sir!
    btw word of caution use a smaller size extractor, i center punch nyo muna yung putol na bolt para naka center yung extractor, use a drill with reverse and variable speed...set muna sa slowest speed "push hard" enough para kumagat ang extractor and apply pulse power to the drill set on REVERSE.
    key word PATIENCE....lalabasan ...este lalabas din yan....
    walang sinabi yung mga case ninyo .... yung sa akin the distributor adjustment bolt ang naputol ko....I have to remove the distributor (along with its "gear")...then I have the risk pa to have metal shavings drop into the engine....whew....PATIENCE lang talaga at pamunas ... para pagnilabasan (este) paglumabas yung bolt e hindi mahulog inside the engine.
    GOOD LUCK!!!
    Feb 2005
    Quote Originally Posted by wildthing
    GOOD LUCK!!!
    tnx sir widthing. i'll take note of that.
Screwed!
