Results 11 to 20 of 48
- 54,304
July 17th, 2016 11:04 PM #11
July 18th, 2016 12:58 AM #12
- Mar 2013
- 84
July 18th, 2016 06:09 AM #13Mines more than 14 years. Cap palang napalitan.. my practice is always 3 parts distilled water to 1 part coolant.. change every 3 change oils.
Although in planning to have it replaced with an aluminum type one. When pocket permits hehe
Sent from my SM-N9208 using Tsikot Forums mobile app
- 54,304
- Mar 2013
- 84
July 18th, 2016 04:15 PM #15I referred to this link for comparison:
Aluminum VS. Copper-Brass Radiator: Final Thoughts
I had a leaking cap before resulting to minor oveeheating if the radiators not refilled immediately. Had it checked by my trusted radiator repair shop, casa, motorix banawe. Same diagnosis.. cap lang problem.
However, since 14years na daw sasakyan.. palitin nadin daw kinalaunan yung radiator, all were recommending an aluminum type one.. so i researched and yun. 😆
- 54,304
July 19th, 2016 01:18 PM #17
Reminds me of a guy posting in here about radiators years ago ... he was so "anal" about the topic ..... basta radiators are involved.
Reading his posts was like rocket science!
- Mar 2014
- 901
July 24th, 2016 02:40 PM #18Your technician is good. He knows. I use distilled water too (Absolute or Wilkins), and I only flushed every 6 months ( vehicle use everyday), or for a year (if the vehicle is often use). I always look and check water in a radiator, and also other point to be check inside the engine bay before starting the engine.
Starmobile Up+
July 24th, 2016 03:28 PM #19
Nabasa ko lang somewhere... Kakainin ng pure distilled water lang yung linings ng radiator sa katagalan.. Forgot ko na kung anong tawag sa type ng corrosion na yun, since water is a solvent unti unti niyang i di disolve yung linings sa loob ng radiator and other surfaces. By adding coolant nababawasan yung effect ng pag corrode ng internals. Meron pa nga sacrificial metal bar na maliit na naka lagay sa radiator cap para siya yung unang kainin ng corrosion at hindi yung lining.
- Aug 2012
- 2,767
July 24th, 2016 04:02 PM #20Yung technician na nagsabi na tubig lang ang gamitin sa radiator does not know the function of coolant. Same lang din ng technician na tinatanggal ang thermostat.
Most probably hindi rin nila alam ang ibig sabihin ng PMS, i.e. they only fix a car problem pag andyan na instead of preventing it from actually happening.
Sent from my D5833 using Tapatalk
In that case, I think NCAP is something that they have privatized.
SC (temporarily) stops NCAP
