Results 1 to 10 of 10
    Jan 2019
    Anu kaya problema kapagmahina ang low beam pero ang high beam okay naman. Napalitan na din nang headlight at yung dalawang 10A na fuse ganun pa din ang hina nang low beam
    Jun 2005
    Quote Originally Posted by xfri View Post
    Check voltage of the low beam wiring if less than 12v.
    If proper voltage, Remove front windshield tint and get an eye checkup
    Sent from my MI MAX 2 using Tapatalk
    ^hahaha
    TS
    try mo rin kung tama cutoff ng headlight mo, baka naman mababa lang
    Dec 2009
    Are you heavily tinted in front?
    If you are..that could be the problem
    Sent from my SM-G532G using Tapatalk
    even light tint can make the difference, to susceptible individuals.
    May 2018
    For some odd reason, naiisip ko yung song ni Corey Hart.
    "And I wear my sunglasses at night, so I can, so I can,
    see the light that's right before my eyes...
    Why is it so dark?
    May 2011
    Automatic transmission - Wikipedia
    Only drive in "daymode" D
    Apr 2009
    check your groundings......
    Feb 2019
    Anu kaya problema kapagmahina ang low beam pero ang high beam okay naman. Napalita Xender Discord Omegle n na din nang headlight at yung dalawang 10A na fuse ganun pa din ang hina nang low beam
    Sep 2018
    Other than burnout bulb, possible cause of the problem would be a blown fuse. Check for melted wires which leads to any of the fuses, if you find any inconsistency replace it if necessary. However, it's still safe to have it diagnosed to your trusted car shop for possible repair. Hope this helps!
Low beam headlight
