Results 1 to 20 of 48
    Oct 2014
    Mine is a 1st Gen Adventure and used to changed coolant every 2 years (average of 20k km per changed) Surprised i was advised by the technician to avoid using coolant and instead to use just distilled water and have a regular monthly flushing daw is enough.
    Aug 2012
    Quote Originally Posted by Gian Paulo View Post
    Hanap ka na ng ibang technician.
    Sent from my D5833 using Tapatalk
    mga bros ..
    napansin ko lang sa radiator ng altis, bakit bukod sa reservoir, meron pa isang tube pabalik sa radiator hose?
    may silbi ba ito? ang effect ba nya, tipong bago pa mag expel ng coolant papunta ng reservoir, eh papaikutin muna nya ulit sa system?
    di ko na ma-edit, additional pic ..
    Oct 2009
    baka imbes na pa tapon pag nag oover heat. papasok ulit siya sa rad hose
    Jan 2009
    Its part designation is "Bypass Hose". It's function is not 100% clear to me.
    However, if you take a moment to analyze it, it seems that it allows for excess water pressure from the high-side of the radiator (driver side) to dissipate into the low-side (passenger side) of the radiator in situations during high-revs.
    Another, more simpler reason would be to allow air pockets/bubbles to escape from the high-side to the radiator neck on the low-side.
    Quote Originally Posted by jaypee10 View Post
    yup ganun na gawa nya bro, but why ..
    yan din isa sa naisip ko, last ko naisip ay baka ito yun dapat para sa supposedly heater, kaso wala naman need ng heater sa atin and para makatipid imbis na radiator design ang i-alter ay i-rekta nalang back sa radiator hose? di kasi kita, but that side tube from radiator cap, is actually 2mm (+/-) larger than the one exiting to the reservoir. makes sense ba? O_o
    who wants to flush his radiator monthly?
    use coolant, po.
    use coolant, po.
    +1
    i heard that 'just water only belief' from a mechanic i've chanced once. and never i did came back to him since.
    Your technician is good. He knows. I use distilled water too (Absolute or Wilkins), and I only flushed every 6 months ( vehicle use everyday), or for a year (if the vehicle is often use). I always look and check water in a radiator, and also other point to be check inside the engine bay before starting the engine.
    Starmobile Up+
    Mar 2005
    Nabasa ko lang somewhere... Kakainin ng pure distilled water lang yung linings ng radiator sa katagalan.. Forgot ko na kung anong tawag sa type ng corrosion na yun, since water is a solvent unti unti niyang i di disolve yung linings sa loob ng radiator and other surfaces. By adding coolant nababawasan yung effect ng pag corrode ng internals. Meron pa nga sacrificial metal bar na maliit na naka lagay sa radiator cap para siya yung unang kainin ng corrosion at hindi yung lining.
    Quote Originally Posted by jmpet626 View Post
    If water is a solvent, then I nor we should not be drinking water since we are born in this world.
    Starmobile Up+
    Mar 2005
    Quote Originally Posted by rodetor View Post
    Starmobile Up+
    Pabasa na lang sir.. Ibang "Solvent" ata yang nasa isip nyo.
    Water, the Universal Solvent, USGS Water Science School
    Our kidneys and water make a great pair
    Our own kidneys and water's solvent properties make a great pair in keeping us alive and healthy. The kidneys are responsible for filtering out substances that enter our bodies from the foods and drinks we consume. But, the kidneys have got to get rid of these substances after they accumulate them. That is where water helps out; being such a great solvent, water washing through the kidneys dissolves these substances and sends them on the way out of our bodies.
    Sent from my D6503 using Tapatalk
    You mention here that water is a solvent, not me. That's is why I questioned YOU, if water is like that, never we, people be drinking it, since our birth.
    Starmobile Up+
    Starmobile Up+
    Edit: nasabi na pala
Radiators
