Results 1 to 10 of 48
- Oct 2014
- 162
June 14th, 2016 05:09 PM #1Mine is more than a decade old. Is it advisable to replace or repair radiators? What maintenance is required if its still dont have visible leaks, Are there antirust additives that will do? TIA
June 14th, 2016 05:23 PM #2
Just make sure to have it flushed regularly, together when you do a tune-up. If your radiator's top part is made of plastic, there is a good chance it will develop cracks on the part where the plastic cover is welded into the metal top. If that happens and you're stuck in traffic, be prepared to deal with an overheating engine.
June 14th, 2016 06:04 PM #3
Most manufacturers recommend you have the cooling system pressure checked when the car has reached five years. Other than that it has a high risk of pressure leak and overheating. Never wait for it to have that predictable problem. These are time changed items
June 14th, 2016 09:24 PM #4
^ can any reputable shop do this pressure testing test on our ride's cooling system or only specialized shops can do this?
- Mar 2014
- 901
June 14th, 2016 11:57 PM #5If still functions well, no leaks or no visible tendency to crack in near future. No need to replace it, maintain it for a while until you find obvious reason to replace it with a new one. What you must worry most is your radiator hoses and bypass hoses. Radiator coolant has anti rust and corrosion inhibitors aside from anti freeze. Most probably required maintenance is to replace radiator coolant every year. Or read your owners manual the required interval in replacing your radiator coolant.
SM-Up+
- Jun 2016
- 6
June 15th, 2016 03:50 AM #6
- Oct 2014
- 162
July 15th, 2016 03:35 PM #7
July 15th, 2016 03:52 PM #8
- Oct 2014
- 162
July 17th, 2016 10:41 PM #9Mine is a 1st Gen Adventure and used to changed coolant every 2 years (average of 20k km per changed) Surprised i was advised by the technician to avoid using coolant and instead to use just distilled water and have a regular monthly flushing daw is enough.
- Aug 2012
- 2,767
July 17th, 2016 10:50 PM #10
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
