Results 191 to 200 of 217
- Feb 2014
- 2,696
January 6th, 2022 08:38 PM #191
- 54,212
January 6th, 2022 08:45 PM #192won't the crocodile's wheels allow the jack to move across the floor to follow the car, instead of the jack pulling on the car?
so,
from pasak to wheels,
we're now at the jack.Last edited by dr. d; January 6th, 2022 at 08:49 PM.
- Feb 2014
- 2,696
January 6th, 2022 08:52 PM #193
- 54,212
January 6th, 2022 08:59 PM #194noted.
not-rough kasi garage floor namin. we see the crocodile movement a lot.
i'm excited at what kleos will come up with next.
maybe a comparo among european, 'merican, and china-made crocodiles...?
or a comparo of the various lifting heads..?
i must admit,
this guy is more suave than kags, and he appears to read his posts and not just paste and paste with little understanding.
heyy,
there's more kleos avatar and less kags avatar.
nahihirapan siguro si kags...Last edited by dr. d; January 6th, 2022 at 09:13 PM.
- Apr 2016
- 203
January 6th, 2022 11:00 PM #195I googled for about 2 hours reading about unibody and jack points, but it doesn't answer my question. I found the jack point in my Forester.
But a discussion I read mentioned:
Jacking Points on a Unibody Car | The Garage Journal
"As noted above, it completely depends on the make and model of car. The owner's manual will only talk about the jack points for the factory jack. The service manual will show you the jack points for a floor jack or lift. Many unibody cars CAN be lifted from the rockers. There are special pads that have a notch for the pinchweld, so the lifting load is spread out along the bottom of the rocker. Other cars have reinforced holes in the rockers for a jack. If you are using a floor jack, you can't go wrong if you lift at the hard points where the suspension arms attach to the tub. Some cars have reinforced subrails, or the attach points for the suspension cradles. Again, it depends."
This means yun pinch weld above is only designed for the screw jack in the trunk. It is not for general jack use. Note the pinch weld fits the factory screw jack head:
During the pasak, they used alligator jack on the pinch weld.
However ang tama is to use rubber support for the pinch weld like this:
Now my question is. For Subaru casa, how do they lift the Forester? By lifting via the pinch weld or are their other jack points written in the service manual and not shown in the owner manual? Remember the pinch weld is only designed for the car factory screw jack. In your car, how does the car lift support your car? via the pinch weld with maybe special pads?
Remember car tire shop is visited by all kinds of cars, so hindi nila memorize lahat na service jack points. This was why the pasak technician tried to lift by car via the suspensions. Should I ask Subaru casa where exactly are the service jack points, which I must convey to the tire shop? This is to ensure hindi ma damage yun pinch weld sa sides which is only very thin vertical metals (still puwede ma bend without pads).
- 54,212
January 6th, 2022 11:14 PM #196google for these jacking points in your subaru forester.
yes, you can approach the mechanics in the subaru casa and inquire.
say,
why not bring your car to the casa, and have it serviced there?
that should put to bed your doubts.
then tell us about it.
... all this, because of a dis-satisfied flat tyre fix...Last edited by dr. d; January 6th, 2022 at 11:27 PM.
- Apr 2010
- 742
January 7th, 2022 08:16 AM #197i could not believe someone is this anal and generated such a long thread from a simple tire leak.
there's a topic nagtatanong kung battery or alternator problem - umabot pa sa grounding points when jump starting, engine ground versus direct sa battery terminal.
hindi daw gumana jumping from engine ground, naging theories and thought exercise instead of what works in the real world. starting the car took weeks and 40 pages ata. this thread is another example of that.
or user might be trolling lol
- Apr 2016
- 203
January 7th, 2022 08:28 AM #198The tyres at Subaru costs 18,000 each daw. And I can't just go inside and look at their service area. And Omicron is surging. One can just pasyal anywhere. And I only knew about the Unibody vs Body-on-Frame last night lang.
About googling the jacking points. That's what I was doing last night. But I came across the following as I mentioned in my last message where the poster said jacking points for users and service car lift is different.
" The owner's manual will only talk about the jack points for the factory jack. The service manual will show you the jack points for a floor jack or lift. Many unibody cars CAN be lifted from the rockers".
I was asking the experience of yapoy86 who made me aware of all these just like night. The Subaru Forester will be my last car. I won't buy a new one anymore. So want to make sure hindi makatulad ng CRV ko na rami na sira because wala ako alam.
- Nov 2009
- 3,507
January 7th, 2022 09:47 AM #199Pasak-pasak in a P18k tyre without verification for other leaks is a no-no. If you'll have to unmount the rubber from the rims, re-balance it esp if used as front tyres. After tyre repair, I always demand removal of tyres and dipping in the tub of water to check for small leaks.
The notch of the jack head in the scissor jack is just to secure from not sliding. It is no different with alligator jack-head since it has wide notch and jack wheels allow movement when weight is shifted during jacking, the contact points will still be on tangent.
The most safe way to Jack at the garage it is by using another jack or steady jack so if ever it slips or jack fails nothing will be damaged. Always read that F user manual (RTFM) if you're unsure.Last edited by 12vdc; January 7th, 2022 at 09:51 AM.
- 54,212
Kapag tinuloy pa yan sigurado magtatagal dahil makikialam ang Taguig LGU.
Makati Subway. Completion date: 2025
