Results 111 to 120 of 401
Tsikot Member Rank 4
- 1,842
September 30th, 2009 12:42 AM #111Our experience on a 97 lancer
(up to ignition key ang lubog)
Naalis ko battery minutes before lumubog
Happened during milenyo.
Sa bahay ko na lang pinaayos. called a Citimotor mechanic at ako na lang helper nya
1. Bought sparkplug, gear oil, air fuel & oil filter, engine oil
2. Remove spark plug and filters, Drain the tank. (Air filter basang basa)
3. Start without the spark to make sure lumabas ang tubig sa block. (Wala naman)
4.Change all fluids and install spark plug and filters, re use old gasoline since no sign of water
5. Remove the ECU. Inabot! Pinunasan then sprayed with WD-40 then kabit ulit.
6. Nag start na.
7. Remove all seats and carpeting. Inuna linisin ang driver seat at kinabit kahit basa pa, para lang may magamit. It became a one seater car with no carpeting.
8. After 4 days reinstall everything
9. Remove car stereo cleaned it with WD-40, gumANA pero radyo na lang.
Spend around less than 3k yata
Other notes:
Speaker is waterproof
Check nyo lalagyan ng Power steering fluid kung inabot.
Sa mga naka stikshift, expect the clutch to become noisy. , dahil chances are yung release bearing magkakabuhangin. Pero kahit next time nyo na ipaayos iyon dahil d naman delikado iyon. mine took two years pa, naupod na din kasi lining
pa check nyo din brake. baka nagkapunit ang piston brake seal/gasket
ECU daw can be check by electrician, yung guwagawa ng appliances. not sure but you guys might give it a try,
Kung ipipila nyo sa CASa iyan, matatagalan iyan better make steps para mabuhay ulit oto niyo, besides void na ang warranty niyan.
Guys
Dont worry about your car, aandar din iyan, sooner or later maeenjoy nyo ulit ang kotse nyo. mas worst pa din ang nabanggang oto kesa binaha. Pareho ko na naranasan iyan.Last edited by MAXBUWAYA; September 30th, 2009 at 12:49 AM.
September 30th, 2009 01:46 AM #112
paano naman kung hindi natangal yung batt connection? masisira ba yung ecu ng oto?
kasi yung altis namin, lagpas bubong. habang lumulubog, nag-on yung radio (release yung cd), then head light, gumana pati wiper. wala na oras kalasin kasi yung batt, bilis umangat ng water.
paadvise naman... thanks
September 30th, 2009 02:01 AM #113
hey guys pano kaya yung mga brand new stocks ng mga CASA... baka may mga casa na submerged din? may nabalitaan ba kayo? nakakatakot bumili ng 2nd hand AT brand new IMHO...
September 30th, 2009 03:45 AM #114
September 30th, 2009 07:39 AM #115
Ako din di ko na natanggal battery sa bilis tumaas ng tubig. 2 months old pa lang yung jazz 09 ko tapos nalubog agad ng baha. I think palitin na yung ECU. Sad to say wala pala akong AOG sa insurance. Di ko na alam gagawin ko sa oto ko. Haaaaay!
September 30th, 2009 08:36 AM #116
Kung umandar yung kotse, you're lucky and everything is still okay. Ibig sabihin walang nasirang IC due to shorts or naputol sa connections due to corrosion duon sa ECU.
You can just clean off any remaining dirt with some WD-40 or contact cleaner and you should be good to go. Bayaan mo nalang yung ibang corrosion na present tanggalin nalang yung dumi na matatanggal.
September 30th, 2009 09:10 AM #117
September 30th, 2009 11:16 AM #118
- Jul 2008
- 114
September 30th, 2009 11:16 AM #119Help po. Our Nissan xtrail suffered damage din because of the flood. Dito kami sa Malate area at halos lubog yung gulong. Pasensya na at lately ko lang nabasa na wag pala dapat i-start ang makina. Nung humupa na yung baha nung Sunday morning, i was able to move it out from the garage. Syempre basa ang carpet hanggang ilalim lang nung driver's seat.
Last Monday na dadalhin na namin sa casa para ipacheck up at ipadetail, nagstart naman sya pero yung AT shift lever e ayaw gumalaw from Park mode. Ano kaya ang posibleng naging problema nito? Parang nakalock sa Park mode. Ive checked na din yung ATF at reddish pa naman sya. Hindi naman inabot ng tubig yung ECU kasi medyo nasa taas pa sya.
Ang haba ng pila sa towing services ng insurance para madala lang sa casa. Thanks kay lazyfoot for posting the number of Romy re towing. Bukas kami nakaschedule sa kanya since nasa Cainta pa daw sya today.
would appreciate any ideas or advice regarding this AT problem ko especially from those who have experienced the same problem before. thanks.
September 30th, 2009 11:20 AM #120
Probably looks like a Coke sakto. Yes, where did you buy it?
Fire Extinguisher for Car: what brand and type...
