Results 11 to 20 of 21
December 27th, 2006 01:21 AM #11
lakas ng gas consumption 500 a day plus tolgate 55.00, baka dahil a/t siya and hindi manual.
sa friend ko 93 gli din city nya is 7-8km/L, hway niya nag 10km/L daw
1++,+++km na reading niya.
ako kasi manda alabang munwalk laspinas then manda 200 a day lang siyempre diesel kasi yon via southexpressway daan ko kasama na trapk
pero sayo laki ng consumo
December 27th, 2006 01:45 PM #13
RE: judging fuel consumption: Instead of judging by how far you go on the money, find out exactly how many kilometers you can go for the amount of gas you're using.
500 php? What gas? Unleaded? Premium Unleaded? or boutique (V-Power, Blaze) Unleaded? What price? With lower grades of unleaded, that's 13.5+ liters, with higher grades, 12.5.
If it's 13 liters, alabang to makati and back is roughly 50 kms. "Almost" empty could mean you're using anywhere from 8-10 liters. Roughly 5-6 km/l? Better make sure.
But considering part of that is on the highway, there's definitely something wrong.
Pull the Bosch sparkplugs and check their condition. If they're a few months old, they should be reddish in color. Have a shop check your compression and check for leaks. Like m_ron suggested, you could be leaking oil through your piston rings, or oil and/or coolant into the combustion chamber through a busted gasket.
If the car doesn't feel like it's losing power, then the problem might be minor... but if it really is a leaking gasket, don't wait too long before having it fixed...
According to rumor on the PTP boards, the JDM/Mazdaspeed ECU for the 323/Familia (96+) has a better timing/fuel map, resulting in more power and better fuel consumption. It's an ECU swap, though, not a re-program... and suwertihan nalang makahanap.
December 27th, 2006 02:36 PM #14
Give us a definite figure of your MPG, tire pressures and current mileage. Mahirap ang tantsahan, even if you check them everyday.
If you're concerned of white smoke at start up, it may just be condensation as water in the exhaust is being burned. If the white smoke persists when driving with a warmed up engine, you better start checking for headgasket problems.
For the 4AFE engine, blue smoke at start up and when driving is usually indicative of valve stem seals.
December 27th, 2006 08:29 PM #15
Merry Xmas to everyone!
Thanks for replies, going to the prob, my uncle who's a mechanic helped me assess the prob, since there were no indications of leaks outside, when he checked the engine, he told me, the engine need Top Overhaul.
How much is that for an engine? prices for b/new parts like valve seals, piston rings and stuff? also, there is an indication that there are misfires of the sparkplugs or rather there is oil on the places where the plugs are placed.
Anyone knows a quote on the prices? thank you very much for the replies again!
December 27th, 2006 08:46 PM #16
Merry Xmas to everyone and thanks for those replies!
Anyway, going back to the problem of my car, an uncle of mine dropped in to help me assess the problem, although there were no signs of external leaks, he told me that the engine need Top Overhaul, it may be so for these cases:
1. slot 2 and 4 for the spark plugs (from the right) have oil leaks. It was also checked if the wires leading to the plugs have currents, they do.
2. the engine oil depletes rapidly (since changed oil a few months ago), and mixtures of water and oil were found at the exhaust.
3. later, at the lower part of the exhaust manifold w/c is attached to the engine , there was a bit of oil buildup at the right bottom side.
4. He also noticed that the torque-y feeling when you go up was missing now.
5. He even told me that there might be some loss of pressure inside (i dunno what that was).
He recommended to me to go Top Overhaul and have it fixed asap. He just came back from the states so we don't know how much that would cost.
Estimates? cost? anyone know a shop that is reliable, trustworthy and is considerate on the prices of the parts?
a friend of mine told me that it would cost around 10-20k depending on the condition.
How much are the parts? anybody knows where i can get good parts? ^_^
Thanks again for the replies and happy holidays!
December 28th, 2006 06:41 AM #17
you don't need top overhaul,have your piston and piston rings checked.check appropriate clearance.
December 28th, 2006 01:31 PM #18
If there's oil on the sparkplugs, then there might be something there.
10-20k sounds about right. Just cross your fingers that you don't need your cylinder head re-faced.
Tsikot Member Rank 5
- Nov 2003
- 3,849
December 28th, 2006 10:22 PM #19looks like you have to crack open the engine na nga to see what the problem is.
January 11th, 2007 04:29 AM #20
My suggestion is to remove the cylinder head then check the head gasket as to where the oil was coming from. Was seeping through the gasket area? Through the valve guides/seals? Or through the cylinder walls (busted piston ring/bore)?
You should have your answers then.
HTH!
in my opinion, the more effective deterrent against car theft, is the visible deterrent. if the...
