Looks like your uncle has things in hand.
The oil might be leaking through the piston rings.
loose compression? It would also explain the oil loss.3. later, at the lower part of the exhaust manifold w/c is attached to the engine , there was a bit of oil buildup at the right bottom side.
4. He also noticed that the torque-y feeling when you go up was missing now.
Basically there is a leak in the engine cylinders. It could be the piston rings or engine gasket.5. He even told me that there might be some loss of pressure inside (i dunno what that was).![]()
The price MIGHT go up depending on what the mechanics will find after opening your engine. If it's just the engine gasket, it would be fine. If you have problems with the piston rings, you might also need to check the cylinder itself if the sleeves need replacing as well.He recommended to me to go Top Overhaul and have it fixed asap. He just came back from the states so we don't know how much that would cost.
Estimates? cost? anyone know a shop that is reliable, trustworthy and is considerate on the prices of the parts?
a friend of mine told me that it would cost around 10-20k depending on the condition.
How much are the parts? anybody knows where i can get good parts? ^_^
Thanks again for the replies and happy holidays!
Given the mention of water and oil in your exhaust and oil leaking out the right side of your engine, it might be the gasket that is leaking.
