Results 21 to 30 of 55
Toyota is my choice
- Aug 2005
- 2,063
September 26th, 2005 02:46 AM #22
it's not "so" bad.... people in the US with oil-eating cars do this all the time..
keep a few liters of cheap motor oil with yourself all the time. keep topping off the engine. even with the busted lands and scored cylinder walls, the engine will still keep running. it will burn oil like crazy though (hence, you have to top off every few days..) it will have crazy fuel consumption, it will emit tons of blue smoke, and it will never pass an emissions test.
you might be better off looking for a surplus 2E engine and doing a full engine swap. a 2E might cost less than 20,000 which is less than the cost of an overhaul.
September 26th, 2005 03:21 AM #23
3E na ang katapat nyan. 1.5L tipid pa rin...12K dito sa Manila ang 3E last I checked. Malamang meron din dyan dahil sa Cebu may importers din from Japan. Hanap ka na lang ng magbubukas to check everything at magkakabit.
- Sep 2005
- 103
September 26th, 2005 10:29 AM #24Ey, hindi kaya ex taxi yang auto mo?
maghanap ka ng honest at magaling na mekaniko, para wala ka na iisipin kapag nagplano ka na ipagawa mo auto mo. yung tipong sasabihin sa iyo lahat ng dapat talaga palitan at gawin sa engine ng kotse mo.
Toyota is my choice
- Aug 2005
- 2,063
September 26th, 2005 05:31 PM #25Originally Posted by Betz
3e? kung pwde ipasok lng yan deritso sa makena ko at wla ng ibang ipa machine shop okey ako dyan po.
possible ba if head gasket lng palitan and mga valve seals babalik na ang compression?
Toyota is my choice
- Aug 2005
- 2,063
September 27th, 2005 01:03 AM #28Originally Posted by BlueBimmer
swerte mo bro ganda ng bm mo at ang astig ng makena.
- Oct 2004
- 21
September 27th, 2005 12:20 PM #29Originally Posted by finchy18
D problema yan! Check natin yan! Bka may singaw lang sa mga vacuum hose mo. Just a little check-up and adjustments OK na yan. Txt me for details 09183000108
- Oct 2004
- 139
September 27th, 2005 12:28 PM #30i'm sure most of us here share your sentiments.
sabi nga nila, ganun talaga pag may sasakyan ka..para ka daw may anak. hindi lang magastos to maintain but you'll worry to death if something's wrong.
hope maayos na sya kaagad para ma-enjoy mo ride mo.
just my 2 cents.
Megawatt charging: https://www.youtube.com/watch?v=usUxO7y4z_E
BYD Philippines
