Results 21 to 40 of 55
    Aug 2003
    if the valves are damaged or the piston rings are busted, loose compression yun.
    pag naubusan ng langis... makakaladkad lahat ng metal parts sa loob kasi walang lubrication. good as dead na yung engine nun. bili ka na ng bago.
    Aug 2005
    patay ako
    Aug 2003
    it's not "so" bad.... people in the US with oil-eating cars do this all the time..
    keep a few liters of cheap motor oil with yourself all the time. keep topping off the engine. even with the busted lands and scored cylinder walls, the engine will still keep running. it will burn oil like crazy though (hence, you have to top off every few days..) it will have crazy fuel consumption, it will emit tons of blue smoke, and it will never pass an emissions test.
    you might be better off looking for a surplus 2E engine and doing a full engine swap. a 2E might cost less than 20,000 which is less than the cost of an overhaul.
    Jan 2004
    3E na ang katapat nyan. 1.5L tipid pa rin...12K dito sa Manila ang 3E last I checked. Malamang meron din dyan dahil sa Cebu may importers din from Japan. Hanap ka na lang ng magbubukas to check everything at magkakabit.
    Sep 2005
    Ey, hindi kaya ex taxi yang auto mo?
    maghanap ka ng honest at magaling na mekaniko, para wala ka na iisipin kapag nagplano ka na ipagawa mo auto mo. yung tipong sasabihin sa iyo lahat ng dapat talaga palitan at gawin sa engine ng kotse mo.
    Aug 2005
    Quote Originally Posted by Betz
    di po to taxi. galing sa manila to sa aunte ko.. medyo luma na first overhaulng car kung pa overhaul sya. sabi ng mechanic head gasket daw at valve seals dapat talaga palitan.. di nman talaga na ubosan ng langis muntik lng.. sumingaw lng to yung pinalitan ko ng bagong spark plugs..
    3e? kung pwde ipasok lng yan deritso sa makena ko at wla ng ibang ipa machine shop okey ako dyan po.
    possible ba if head gasket lng palitan and mga valve seals babalik na ang compression?
    engine swap na yan... nangungulit lang bro :D
    Dec 2003
    perfect time for a 4AGE swap
    Aug 2005
    Quote Originally Posted by BlueBimmer
    kung may time lng ako bro ksi use ko to araw-araw kasi nasa college pa ako.. kung may reliable mechanic na nagawa na nya mag swap pwde na din pa swap.. hehehe
    swerte mo bro ganda ng bm mo at ang astig ng makena.
    Oct 2004
    Quote Originally Posted by finchy18
    mga tsikoters pls po help mga kuya sa problems ko.
    1.) sumisingaw ng malakas air breather ko. ( "sheshhhhh "grabe lakas talaga)
    2.) pag tapak ko ng brake parang namamatay engine ko ( bumababa rpm hindi na normal to )
    3.) may kaunting langis ang mga spark plugs ko ( valve seal daw kasi maputi na ang usok )
    4.) gastos na nman kahit binibaby ko na ang car ko. ( parang baby mag alaga ksi ako )
    carburator po engine ko 2e engine 96' corolla xe
    pls po.. di ako makatulog nag troubleshoot pati isip ko. waaaa...!
    help po mga expertz... kuya help!
    D problema yan! Check natin yan! Bka may singaw lang sa mga vacuum hose mo. Just a little check-up and adjustments OK na yan. Txt me for details 09183000108
    Aug 2005
    Quote Originally Posted by aquaman
    buti nlang kung ganun lng sir.. pro kung pa overhaul na to patay ako d2.. wawa naman baby ride ko 3 days standby na.. baka kasi masaktan na naman ulit.. san po un vacum hose sir? ano po yong sumisingaw sa air breather ko? yong air breather na malapit sa oil cap.
    from cebu me kung sa dyan me sa pasig deritso ako dyan.
    Oct 2004
    i'm sure most of us here share your sentiments.
    sabi nga nila, ganun talaga pag may sasakyan ka..para ka daw may anak. hindi lang magastos to maintain but you'll worry to death if something's wrong.
    hope maayos na sya kaagad para ma-enjoy mo ride mo.
    just my 2 cents.
    Aug 2005
    Quote Originally Posted by rayana
    just my 2 cents.
    ganun po talaga pag baby mo na car mo. thanx po
    Jun 2004
    Baka naman hindi pa talaga sira iyan. I-liter of oil every three months is not so bad. May iba nga 1-liter every day (pero taxi iyon). Just check your oil every morning before starting your engine and add if necessary. And sabi mo 70T km pa lang tinakbo - mababa pa iyon. check other possible sources of your troubles first before going into an overhaul or engine replacement.
    Aug 2005
    yes sir.. mga tsikoters mga bros.. GOOD NEWS.. yehey! nawalan ng problema ko at maluwag na hiniga ko.. *cough* ehhm.. isang tube lng pala malapit sa oil cap yong direct line sa carburator ay sira na.. pina tingin ko sa isang lolo na expert mechanic pinakinggan lng ang engine ko sabi nya okey nman at maganda pa tunog ng makena ko at tingangal nya ang tube tapos dun na off engine ko tapos sabi nya start ulit tapos sabi nya.. ah... ayun Sapul ka! .. iba talaga kpag lady driven galing ang car ko hindi abusado.. hehehehe.. pinalitan lng ng tube worth 220 nalimota ko name eh basta mayroong "valve" din.. ayun balik na sa normal wala ng hissing.. weeee! ligtas sa overhaul baby ko at gastus.. salamat talaga mga pre na hindi pa dalos dalos.. weeeeeeeeee
    Thread close
    Dec 2003
    sabi na nga ba malabong overhaul sa 70k na tinakbo e hehe
    sayang, 4age na sana. hehehe. joke
    congrats! buti na lang at un lang problema.
    Aug 2005
    ano byun 4 age? uhmm.. im interested ..hehehe
    4AGE yung tawag sa makina ng 1.6GLi na Toyota (yun sa iyo ay 2E series). Eto yung 16valve na DOHC engine, which when properly modified ay pede mo nang ipang karera yung oto mo sa drag-strip.
    Goodluck!!!
    Aug 2005
    Quote Originally Posted by wildthing
    Goodluck!!!
    wow.. ganda ng 1.6 gli bor DOHC pa.. nag tanong ako sa mechanic ng isang shop sabi nila kaya nilang convertiong sa 1.3 to 1.6 GLi..takot ako sa mechanic nila eh baka masira lng tsikot ko at bka gawing experiment .. gusto ko pero dami palitan at ipa gawa..
    mayron naba nka try nyan dyan sa manila? okey ba results ng swap? wlang taguk-tok?
di makatulog dahil sa car problem ko
