Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 55
    Aug 2005
    #21
    patay ako
    Aug 2003
    #22
    it's not "so" bad.... people in the US with oil-eating cars do this all the time..
    keep a few liters of cheap motor oil with yourself all the time. keep topping off the engine. even with the busted lands and scored cylinder walls, the engine will still keep running. it will burn oil like crazy though (hence, you have to top off every few days..) it will have crazy fuel consumption, it will emit tons of blue smoke, and it will never pass an emissions test.
    you might be better off looking for a surplus 2E engine and doing a full engine swap. a 2E might cost less than 20,000 which is less than the cost of an overhaul.
    Jan 2004
    #23
    3E na ang katapat nyan. 1.5L tipid pa rin...12K dito sa Manila ang 3E last I checked. Malamang meron din dyan dahil sa Cebu may importers din from Japan. Hanap ka na lang ng magbubukas to check everything at magkakabit.
    Sep 2005
    #24
    Ey, hindi kaya ex taxi yang auto mo?
    maghanap ka ng honest at magaling na mekaniko, para wala ka na iisipin kapag nagplano ka na ipagawa mo auto mo. yung tipong sasabihin sa iyo lahat ng dapat talaga palitan at gawin sa engine ng kotse mo.
    Aug 2005
    #25
    Quote Originally Posted by Betz
    di po to taxi. galing sa manila to sa aunte ko.. medyo luma na first overhaulng car kung pa overhaul sya. sabi ng mechanic head gasket daw at valve seals dapat talaga palitan.. di nman talaga na ubosan ng langis muntik lng.. sumingaw lng to yung pinalitan ko ng bagong spark plugs..
    3e? kung pwde ipasok lng yan deritso sa makena ko at wla ng ibang ipa machine shop okey ako dyan po.
    possible ba if head gasket lng palitan and mga valve seals babalik na ang compression?
    #26
    engine swap na yan... nangungulit lang bro :D
    Dec 2003
    #27
    perfect time for a 4AGE swap
    Aug 2005
    #28
    Quote Originally Posted by BlueBimmer
    kung may time lng ako bro ksi use ko to araw-araw kasi nasa college pa ako.. kung may reliable mechanic na nagawa na nya mag swap pwde na din pa swap.. hehehe
    swerte mo bro ganda ng bm mo at ang astig ng makena.
    Oct 2004
    #29
    Quote Originally Posted by finchy18
    mga tsikoters pls po help mga kuya sa problems ko.
    1.) sumisingaw ng malakas air breather ko. ( "sheshhhhh "grabe lakas talaga)
    2.) pag tapak ko ng brake parang namamatay engine ko ( bumababa rpm hindi na normal to )
    3.) may kaunting langis ang mga spark plugs ko ( valve seal daw kasi maputi na ang usok )
    4.) gastos na nman kahit binibaby ko na ang car ko. ( parang baby mag alaga ksi ako )
    carburator po engine ko 2e engine 96' corolla xe
    pls po.. di ako makatulog nag troubleshoot pati isip ko. waaaa...!
    help po mga expertz... kuya help!
    D problema yan! Check natin yan! Bka may singaw lang sa mga vacuum hose mo. Just a little check-up and adjustments OK na yan. Txt me for details 09183000108
    Oct 2004
    #30
    i'm sure most of us here share your sentiments.
    sabi nga nila, ganun talaga pag may sasakyan ka..para ka daw may anak. hindi lang magastos to maintain but you'll worry to death if something's wrong.
    hope maayos na sya kaagad para ma-enjoy mo ride mo.
    just my 2 cents.
di makatulog dahil sa car problem ko
