Page 4 of 195 FirstFirst 123456781454104 ... LastLast
Results 61 to 80 of 3900
    #61
    Getting 6++ km in the city with those types of engines really isnt bad. Our 2.0 Cefiro used to do the same when the traffic gets bads... Heck Toyota Revo owners have it worse.
    If you're still under warranty, try to stick to the CASA as much as possible as the warranty may come in handy (on our Sentra, we had some warranty work done right before it expired... saved us a few grand). The 20K service usually is costly as you have to change filters as well. Then, every 40K, all the fluids and filters have to be changed. If you're on a budget, it's still more cost effective to use your mineral oil as changing every 5K is still the best practice in our driving conditions.
    Try to observe the performance in the long run... I'm wondering if the QR engines have the same hiccup as the QG engines on the Sentra Grandeur wherein the performance suffers when the MAF gets dirty (which can easily be cured by cleaning the MAF with contact cleaner every 10,000km or so).
    Oct 2004
    #62
    Originally posted by Kizoku
    Yes. :D
    Why?
    parang putot. its the first thing i changed. made it stebel. sayang walang nautilus when i changed it.
  3. #63
    johnnyd: How much for the stebel?
    vinj: Sorry for the stupid question, what is MAF? If I get at least 7km/li, I'd be happy.
    Oct 2004
    #64
    stebel cost 700-800 yata.
    Dec 2004
    #65
    just got my xtrail 250x today....ang saya saya ko =) question to other x-trail owners, mabilis ba masira yun 6-cd in dash HU ? kase had bad experience with in dash changers before. weird nga eh mas maganda ang radio ng 200x pwede mp3. sana yun na lang rin HU ko. thanks
  6. #66
    eks: congrats on your purchase. what color did you get? I heard that they had two new colors: passion orange and a dark metalic silver.
    #67
    charcoal grey kinuha nyan! hehehehe!!!
    kahit pilay, pinick-up yung sasakyan nya! yan ang excited! bwahahaha!!!
    oy, pasasakayin mo ako dyan ha.. pagasgas sa leather seats mo ha :p
    Oct 2004
    #68
    ok yung color ng x mo, di halata dumi. gusto ko na nga palitan ang hu ng ride ko not because di maganda kundi kukuha ng mas maganda. ok naman yung hu pero we still dont know kung magtatagal.
    ILuvDetailing
    ok na sound setup mo?
    #69
    MAF: Mass Air Flow... it's the sensor right after the airbox. It takes the air intake flow reading for the ECU.
  10. #70
    JohnnyD: Di pa still getting the parts, already have the 10" PG Subs, gagawin ko pa yung box, looking for a v12 507 amp (medyo malabo since wala na ako makita sa raon), might settle for a 705, am buying the targa separates (not sure what size, I'll measure it once i find the time). Budget setup muna, hehehe. Naka sound setup ka ba?
    Am looking for entry point on the firewall para sa power cables (amps) anybody know where it is located? Am warry of drilling holes.
    Finally am getting around 7.1km/li on my exy on the city. Hope this holds up or improves
  11. #71
    Quote Originally Posted by vinj
    How do you clean the MAF? Pwede kaya DIY?
    Dec 2004
    #72
    Saan magandang bumili ng accessories para sa X-trail natin maliban sa casa?
    #73
    It can be DIY'd once you know where it is and you can access it (usually by dissassembling the airbox)... just spray it with a good contact cleaner. Just don't touch the sensor pin itselg as the part is sensitive.
    For X-Trail accessories, a trip to Banawe can help (try checking out Autospecs).
    Dec 2004
    #74
    *vinj
    Thanks for the tip.
    #75
    You can check with your CASA service advisor regarding that (where do you go for service BTW?). Ask him if the Xtrail MAF sensor is as sensitive to dirt as the the one from Sentra Exalta Grandeur.
  16. #76
    Got my Exy serviced at Nissan U.N., problem with casas is that it takes a long time to get your car serviced. Kung pwede I-DIY, I'll take the DIY route.
    O.T.: Is Nissan U.N. affiliated with Nissanbayan?
    #77
    UN Ave? Nope...
    It really takes time sa CASA. We go to Nissan Gallery Quezon Avenue usually (relatively better service based on my experience).
    Jul 2003
    #78
    Hi! This is my first post in this board. I've been lurking around this board for quite a while now. I've found your topics to be very informative and entertaining.
    Anyway, We just got our X-trail 250X two weeks ago. I'm a little bit disappointed to find some minor problems with the car. I hope you guys can shed some light on this.
    1. Wiggle on steering wheel at 100kph to 115kph -- I was very disappointed here. After getting our car, we drove it directly up north via NLEX. Starting at 100kph, the steering wheel wiggles noticeably. Of course it irritates me since this is a brand new car. Above 115kph, the wiggle disappears. Below 100kph, there is no wiggle. I brought it back to the casa to have the wheels balanced. I tested it again at NLEX. This time, the wiggle was a little less, but it was still there. What gives? Could the balancing still be improperly done? Any other source of wiggle problems on a brand new vehicle with less than 200km on the odometer? Another problem is, we have to drive it to NLEX to test it since we need to hit 100kph.
    2. Vibration on hood -- Xtrail owners, pls try this. With the engine running and a/c turned on, step on the brakes and shift to Drive, and just stay put with foot on the brake. Look at your hood infront of you. Does your hood vibrate noticeably? Mine does. If you let go of the brakes and start crawling, the vibration disappears. Or if you step on the gas a little (w/ brakes still depressed) to increase the rpm by 50-100, the vibration disappears. If you shift to Neutral, there is no vibration. This happens when the engine is warm already. Is this caused by a low idle RPM? Is there a way for the casa to increase the idle rpm by 50-100? I know new engines now are computerized, so I don't know if it's possible.
    3. Brake dust -- there are lots of it, esp in the front wheels. Is this normal for a new car? or is it really inherent to the xtrail since it's wheels are somewhat "open" design.
    4. Glove compartment - hard to close, and comes out completely at times. I guess this has been the flaw so many others have reported. I had it fixed last week, and so far, it's still holding up. The glove compartment feels cheap.
    This is it for now. It makes me doubt if I made the right choice getting the Nissan. It's our first Nissan. We've owned Hondas and Toyotas eversince.
    Thanks in advance.
    Dec 2004
    #79
    *yenners81
    #s 1, 3 & 5: We didn't have these problems.
    2. I think this one is normal since you are trying to prevent a car from moving forward. Kung baga, may "laban". I am not sure about this though but this vibration is also present in our sedans w/c have smaller engines.
    Jul 2003
    #80
    Thanks for the reply Kris.
    The #2 problem is not present in our other automatics (97 Civic and 97 Accord). It seems like the rpm is a bit too low when you shift to Drive.
    Another thing is the aircon in the 250x. Each time you switch on the aircon, the air-recirc switch always goes back to "outside air". Kinda annoying since you have to press the recirc switch everytime you turn on the a/c. Anyway to fix this for good?
Nissan Xtrail Owners: Questions and stuff
