Results 1,081 to 1,090 of 1303
- Jan 2006
- 230
March 20th, 2011 12:17 AM #1081bro ron - on pure gas--mababa talaga ang idle ng vanette on morning start up..wala sya ng automatic choke na pwede magadjust ng idle for fast warm up..or like EFI na may sensor for cold engine....ganyan din sakin..basta one click lang on ignition start at di mamatay until its idle setting(usually stable at 800 rpm on operating temp) ibig sabihin maganda pa tune up ng carby mo..
- Apr 2010
- 19
March 20th, 2011 10:25 AM #1082thanks sir Shauskie pero sa akin namamatay minsan dahil sobra bumabagsak idle... at cold start-up kailangan ko apakan gas pedal para hindi mamatay kagad.. just to make sure gusto ko patune-up siya.. may alam ka ba magaling na mechanic sir malapit dito paranaque.. by next week kc papacleaning ko aircon ko para isasabay ko na isang buong araw ko papagawa.
March 20th, 2011 09:17 PM #1083
Sir ron,
Sa umaga when you start the van do you pull the choke lever? Kailangan ito kapag malamig pa ang engine mo para maging rich ang mixture mo and tataas ang idle mo. Manual kasi ang choke ng vanette kaya you have to manually do it yourself. Sa ibang kotse automatic kasi ang choke hindi mo na ginagawa ito.
- Apr 2010
- 19
March 21st, 2011 09:18 PM #1084
- Jan 2006
- 230
- Jan 2006
- 230
- Apr 2010
- 19
March 23rd, 2011 12:21 AM #1087
- Jan 2006
- 230
March 23rd, 2011 09:44 AM #1089no..di sya iniikot sa vanette..di mo talaga maiikot..just pull it to desired position..di sya babalik unless pushed back again....yung iniikot is para maglock...i never use choke also..minodify ko na rin yaang nasa akin...i used it as cruse control on hiway driving....pag gusto ko mag rest and relax ang right foot ko from pedal..i just pull it para sya na mag sustain ng desired speed ng van...para nal ng din akong pasahero di ba...
..dinisconnect ko na yan sa butterfly ng choke sa carb...connected na lang sya sa accelerator thottle...
- Apr 2010
- 19
March 23rd, 2011 09:12 PM #1090ok sir thanks uli... kaya siguro medyo malakas sa gas van ko lagi siya naka pull!.... try ko din modify to gaya sir shauskie.... baka may DIY instruction ka sir much THANKS na din...
^ serpentine belt Pala nagpapa-work Ng water pump sa k20 engine. Salamat Naman at ayuz pa...
waterpump area may konting leak
