Results 31 to 40 of 1303
- Oct 2008
- 11
December 2nd, 2008 03:49 PM #31Pare bongskie,
Salamat sa info mo. Patulong pa ulit pare.Nasaan ba makikita yung bleeder screw ng PS pump ng vanette. Me kaibigan tayo me hangin yung PS pump nya.Thanks again.
- Oct 2008
- 8
December 10th, 2008 06:04 AM #32makikita mo yung bleeder sa may fuel filter. 10mm na bolt sa may gilid ng fuel filter holding cup.
- Sep 2006
- 106
December 20th, 2008 01:19 PM #33Yun Vanette 96 ko napa-LPG ko na, ilang months na rin. Nailipat na rin dati pa yun condenser at nalagyan na ng auxilliary fan so walang heating problems. Yesterday lang, pina-3M Magic Tint ko, nasa P5k. Nasa P17/liter ang gastos ko sa fuel. Since nagbaba ng P2 ang gas kanina, baka umabot pa sa P15/liter ang lpg fuel. Baka lower pa.
December 20th, 2008 01:57 PM #34
Bro., smdelfin, please keep the group up to speed on your van's performance after its LPG conversion, since the tank's location, I assume, is in the same 'compartment' as the passengers. I am keeping my gas-fed option for now....
7101:hooray:
- Dec 2008
- 2
December 22nd, 2008 04:35 PM #35Hi Guys!
Newbie here.
I'm having car problems with my van (94 vanette) which runs on unleaded fuel.
According to my mechanic, the engine needs to be replaced.
Do you have any recommendations on where I could find a good 2nd engine?
Thanks!
- Sep 2006
- 106
December 24th, 2008 12:13 PM #36Banawe. I suggest you stick with gasoline, instead of diesel, so that in the future, you have the option of adding lpg, just like what i did with my vanette.
- Dec 2008
- 2
- Jan 2009
- 7
January 8th, 2009 11:09 AM #38Sir Bongskie and Smdelfin Good day po, i just want to ask meron kc ako vanet 95 model, may bahagyaparang lumalagutok sa pang ilalim pag liliko ako sa right turn, nung pina taasko ito last change oil ko ginalaw yung gulong ko sa right (front) medyo may play na sya may kinalaman ba ito sa tumutunog pag liliko ako, Saka isa rin napansin ko medyo mas lamang ang kain ng gulong sa loob. I would appreciateif you could help me with this inquiry. thanks and God bless (Erwin)
- Oct 2008
- 8
January 9th, 2009 02:49 AM #39magandang araw Mr. Erwin. Base sa sinabi mo na "mas lamang ang kain ng gulong sa loob", ibig sabihin hindi na tama ang alignment ng gulong mo sa harap. Either both of the front wheels ay wala sa tamang alignment. ngayon dun naman sa may "lumalagutok" sa ilalim kung paliko ka ng pakanan, malamang wala ng grasa yung mga balljoints nya. Either both lower ang upper balljoints. May posibilidad din baka gastado na yung mga rubber bushings ng lower at upper arm suspensions on the right wheel. I suggest have it check your vanette for chambering(wheel aligment). my last advice to you Mr. Erwin, if you have it check, make 2 to 3 different shops to check it? anyway its free for check and estimate. after that, find out the differences because that would be an advantage before you agree to have it repair your vanette. goodluck pare.
- Jan 2009
- 7
I use imgur.com. Upload the picture there, then get share links, choose bbcode and paste here.
Mineral , semi synthetic or fully synthetic?
