Quote Originally Posted by TheUninvited View Post
Well after coating with TD, it got rained on after 14hrs.
Hopefully it has cured already. Nilalagyan naman daw nila ng Reload pag maulan para sacrificial layer.
Been a month now since, and I'm seeing less water beading already. I guess that's normal lang.
Personally, I prefer extensive water sheeting than beading. Yes, beading looks cool to watch but the main purpose of coating is to quickly repel water as much as possible to avoid watermarks and facilitate touch less drying. If water sheets quickly then I am assured that the coating is serving its main purpose of repelling water.
Did TD conduct a "before" and "after" paint thickness measurement on random areas of your panels for your reference? If so, you can point out the areas where the coating failed due to significant variance in paint + coating thickness when you bring your car to TD for inspection. I assume TD applied the consumer grade CQuartz UK ver 3.0 to your car.
