Page 648 of 729 FirstFirst ... 548598638644645646647648649650651652658698 ... LastLast
Results 12,941 to 12,960 of 14580
    Jun 2008
    #12941
    Quote Originally Posted by flash1919 View Post
    hi good day sirs,
    just wan to ask if you have any idea how to erase those white triton markings found on window visor and hood guards? TIA
    kuyang bakit ayaw mo nga triton hehehehehehehehe
    Mar 2007
    #12942
    Hi sirs of Bosb!!! Just wanna ask regarding on the locks of the stradas, Does it automatically lock itself if putting pressure on the brakes? coz most of my cars does.. I am just baffled that my unit does't. please help me on this.. Thanks so much po>>
    Jan 2010
    #12943
    Quote Originally Posted by gdown View Post
    did you mean does its doors lock if putting pressure on the brakes? if this is the case, this never happened to all the vehicles i've driven. what i know is that doors automatically lock when you turn on the ignition (feature of the automotive security).
    Jun 2007
    #12944
    ako din! makikisali sa lock issues!
    ask ko lang mga bosb's na may experience sa winterpine
    yung sakin kasi pag pinindot yung lock button....tumutunog and nag aarm yung alarm nya....ang problema inde sumasabay yung Lock....so ang nangyayari naka arm lang yung alarm nya pero inde nag lalock yung auto.... ano kayang problema nito? actuator din kaya? hhhmmm
    buti nalang nalaman ko agad na inde nagla lock kasi I make it a habit na icheck yung door handle na naka lock talaga before I go.....so sana kayu din....
    kasi you'll never when problems would strike...
    anyway....about naman sa winterpine....pag nagpunta ba ako dun pakita ko lang yung warranty booklet gagawin na nila yung problem?
    Sep 2004
    #12945
    Quote Originally Posted by bigtrak View Post
    salamat po mga sir!, reasonable naba ang 8k for swap ng stock with bridgestone 245-70-16 HT? mga boss tanong lang mas mataas naba yan sa height nyan sa stock tires?
    255-70-16 safe paba?
    mas mababa conti ang 255/70 vs 205/80. the measurement of 70 height vs 80 height
    mahal ba swap 8k daw from stock 205/80 to 245/70 bridgestone h/t sa evangelista?
    are these new tires sir? how much kunin nila yung stock tires mo and how much cost ng tires of 245? thats one way to see if your paying the right amount. what you can do is seperate mo yung two cost.
    Quote Originally Posted by jojitb View Post
    wouldn't changing the tire size of our GL/GLX void our suspension warranty? mahal pa naman ang piyesa pang-ilalim
    as long as within the standards of strada, they should not void the warranty.
    sir our alarm doesn't have that feature. usually those alarms are those that doesnt lock when you switch it on, but when your about to move, thats when it locks. yung iba nga meron delayed seconds as soon as you start moving. our auto lock when all doors are closed and you will start the car.
    yung sakin kasi pag pinindot yung lock button....tumutunog and nag aarm yung alarm nya....ang problema inde sumasabay yung Lock....so ang nangyayari naka arm lang yung alarm nya pero inde nag lalock yung auto... ano kayang problema nito? actuator din kaya? hhhmmm
    bro..check mo muna yung settings ng alarm mo..pwede naman alarm on but the locks doesnt lock. for example, if tamad tayo mag arm ng car or nag pa carwash, we have 30 seconds yata, then the alarm will go on but locks will not lock.
    actuators job is to lock and unlock the locks, therefore, if nag lock naman manual all doors, then wala ka problem with the actuators, maybe its the settings that you have to check. now if nag stock up or you hear the motors of actuator continously running, then meron problem yung actuator and rods. just bring it in winterpine, but best to contact them before going.
    Jun 2009
    #12946
    Thanks guys for answering my previous inquiry on riding comfort. It's very informative
    Speaking of alarms, how do you change the settings by remote? I don't have an alarm manual since i bought a second hand unit
    TIA
    Jun 2007
    #12947
    That feature is not in the Strada. On the other hand the lock will engage automatically if all doors are close prior to starting the engine or when dis-engaging the hand brake.
    But if one of the door is open don't expect that the door lock will automatically engage. There are some vehicle that will lock automatically once the speed reach 15 km/hr.
    Feb 2010
    #12948
    hi sir!
    malamang tama ka nga....hehe taga ibang planeta yun hehe...
    anyway...sana sir maka join ka na sa club!
    yup. naka join nako sir sa mindanao chapter.
    Dec 2007
    #12949
    Quote Originally Posted by katana View Post
    yeah, from mindanao chapter si bro katana...
    #12950
    hi strada gurus, after months of pondering I have decided to take the plunge and get a strada (I was torn between the ranger and the strada). I am getting the GLS model, now the problem is where the get the best deal, the most freebies that wont create a hole in my bank account. Below is the link of a fairly good deal, any inputs will be highly appreciated BTW, im from the province and Im contemplating of driving it from manila, para ma break in agad
    On a side note, what turned me off initially was the turbo of the strada, non VGT type, sabi ko to hell with the conventional turbo, low torque and hp rating, but when I had the chance to drive one, I found the power more than adequate, \after all its a pick up and not a race car
    TIA guys
    http://http://www.sulit.com.ph/index.php/view+classifieds/id/841731/188K+all-in+cashout!!!+-+2010+MITSUBISHI+STRADA+GLS+2.5L+4X4+M/T+CRDI+EURO+II+COMPLAINT
    Sep 2004
    #12951
    Quote Originally Posted by wayward View Post
    On a side note, what turned me off initially was the turbo of the strada, non VGT type, sabi ko to hell with the conventional turbo, low torque and hp rating, but when I had the chance to drive one, I found the power more than adequate, after all its a pick up and not a race car
    TIA guys
    try messaging xave
    Aug 2007
    #12952
    [quote=katana;1430211]
    Quote Originally Posted by nismo26 View Post
    uy sir ken... nice to see you here * tsikot...
    no doubt bout strada....
    davao ka pa ba or manila na? hope to see you this saturday... same place
    yup. still in davao sir. attend ko ng eb natin this coming saturday. meron pa ko recruit if he can make it to come here in davao sir. he he he... para mag dami tayo dito parang gremlin. he he he... joke lang. see you sir sa eb.
    yeah.. sana nga dumami tayo parang gremlins..
    sana kumpleto tayo sa motorcade..
    hi sir!
    bro, member na siya... hanapin mo lang pogi sa sa davao eb pix..
    pogi naman lahat eh... pinpoint ka nalang kung sino type mo...
    hahahaha... sama ka sa mt. pulag? sayang, ganda pa naman sanang sumama.. hehehehe
    Jan 2010
    #12953
    Same problem with mine. I went to casa this afternoon kasi bigla lang nawala ang alarm at auto lock ko. The technician checked and found out the following:
    1. Alarm blackout = fuse damage, replaced the fuse now alarm ok na.
    2. Auto lock = suspect the module is the problem, no stocks of module in the paco casa so i have to go to their main office sa may sta.mesa kasi daw dun maraming stock and stand-by technician. So bukas agahan ko pa punta dun. Magkita na lang tayo dun. He.he.he. I got a beige glx 2010.
    Just bring your OR/CR yun lang daw.
    Dec 2009
    #12954
    (Strada) Nope it doest lock on it's own, regarding the alarm with your other cars. The alarm of your other cars is different than the Strada's security alarm system.
    Jan 2010
    #12955
    Quote Originally Posted by dadz View Post
    brand kasi ng pintura yan, hahaha, balak ko kasi gawin ralliart, hehe, acetone lang pala, nagawn na ng paraan ni sister, dito ksi kami cotabato ngayun, naaiwan sa kanya ung strada, at viola natangal nya triton markings, post ko picture pag natapos. hehehe
    pahabol: kelan ba mag ka EB dito sa mindanao para maka pag member?
    Aug 2003
    #12956
    monday or tuesday daw ma release ang unit ko, through Xave. Ang bilis ng usapan. Maski di kami nagkita ng personal ni Xave, cellphone lang, tapos di ako pumunta sa union motors, puro telephone lang, DEAL!!
    Jan 2010
    #12957
    Yung sa akin rin 2 weeks pa lang unit ko, kapag remote ginamit mo, ayaw mag-lock pero gumagana alarm, kapag sinusian nag-llock naman. Binalik ko sa casa lumuwag lang yata lock sa cable ng central lock. 10mins. lang ginawa ok na. Sana hindi na magloko...
    #12958
    TIA guys
    Good choice sir. Ranger is also good but of course it is more pricey, lalo na sa maintenance cost...compared to strada.
    Yep, It's not a racing car, but it's fast enough to take you from A to B. It's turbo is perfect for the current road conditions in our country.
    where the get the best deal?
    Siguro po ang sasagutin ko na lang is "how to get the best deal?"
    sir, marami pong dealer na pwede kayo mag inquire and do comparison.
    at marami din pong agent/sales executive kayong makikilala. for sure lahat sila magaling mag-sales talk. :D
    for me, It took me almost 6 months to look for a best deal, multiple banks and different dealers & agents/sales. syempre sa tulong na din ng thread na ito.
    Consider nyo po ito:
    1. interest rates vs cash.
    - yung mga ALL-IN na sinasabi, malaki po ang interest nyan pero yun lang hinde na kayo mag-iisip pa lalo na kapag pasok sa budget nyo yung downpayment at monthly amortization.
    - cash, nagkakatalo na lang dyan ano yung free (kuno) items nyo.
    2. straightforward at walang patumpik-tumpik kausap na agent/sales.
    - dami ko nakausap, paiba iba ang prices, yung iba daming promises na in reality hinde naman kaya talaga ibigay makuha lang ang deal.
    Goodluck po sir
    Jan 2010
    #12959
    the reason for erasing the marking is this
    closer
    best mod
    Sep 2005
    #12960
    *flash1919
    sir, ano po brand ng rims nyo? ano po ang sukat ng tires nyo? san nyo po binili? tsaka,magkano po? hehehe...
    salamat...
