Page 269 of 470 FirstFirst ... 169219259265266267268269270271272273279319369 ... LastLast
Results 5,361 to 5,380 of 9388
    Aug 2008
    #5361
    Out of curiousity, how is the immobilizer enabled/disabled?
    You have to you use the keyless entry to disable the immobilizer?
    There is a sensor that detects the OEM key or the keyless remote? (there is something in the key/remote?)
    If you open the door locks with the key, you can't start the vehicle?
    And also...
    Do anyone of you know of a shop who has the template for the floor matting of the Montero sport? Since we got our Montero and the rains started, it's been really difficult keeping the floor clean. We only have the 5pc 3M Nomad matting pre-cut for sedans and sadly some parts are not covered. I would buy the 5pc mat sold by the casa if it is indeed a good fit but sadly it is made of fabric. I really want a Nomad type of matting. It doesn't matter if it is a 3pc or a 5pc set, all I need is a good fit.
    Oct 2008
    #5362
    Quote Originally Posted by fermontalban View Post
    And also...
    from wikipedia...
    An immobiliser or immobilizer is an electronic device fitted to an automobile which prevents the engine from running unless the correct key (or other token) is present. This prevents the car from being "hot wired" after entry has been achieved.
    every ms key (which has embedded chip inside the rubber head) are programmed specifically on each unit. you can't start the engine using an ordinary key (copied). copied key can only be used to open the door but can't be used to start the engine. it is a feature that will deter carnappers so why disable?
    #5363
    Quote Originally Posted by kanuto123 View Post
    sir howie for me 35w china/taiwan/branded(but sill its china/taiwan but the difference is maganda ang market nito) has a little difference in light to a 50w hid kit. im using taiwan hid kits for around 6 years na in my van (head/fog lamps) nung pinag tabi ko yung branded hid 50w ng tropa halos parehas lang gusto ko na din mag palit nun ng 50w but my tropa selling accessories told me hindi na neccessary good thing mahina din kumain ng kuryente ang 35 watts good for my loaded vehicle ....
    for me konti lang naman difference ng 35w - 50w in light even branded ones pero kaw na din mag dedecide kung ano talaga gusto mo heheheh ..... but i heard din sa tropa ko may ilalabas daw sya 70w hid kit taiwan made siguro naka shades ka na sa loob + tint makaka pag drive ka pa sa gabi ....
    +1 here preference lang mga sirs. what is important is the right chosen color temperature. so choose the right and most effective to each one's look
    Aug 2008
    #5364
    Quote Originally Posted by j*sto View Post
    from wikipedia...
    I never actually wanted to disable the immobilizer. I sort of know what an immobilzer is, but I was curious as to when the immobilizer is enabled or disable, i.e. when does the car know that you are using the right key (disable the immobilizer) or the wrong key (enable the immobilizer).
    So there is a chip inside the rubber head. So I'm guessing there is a sensor somewhere in the key slot?
    I got confused, because I was reading the Code Alarm owner's manual and one of the features is "starter disable" which I assume is the same as the immobilizer. Correct me if I am wrong, I thought Code Alarm and the OEM key to the Montero is independent from each other, as Code Alarm is just an add-on accessory to our car just like the JVC HU. So initially, I thought the immobilizer is controlled by the keyless entry.
    By the way, the reason I was reading the Code Alarm manual is because I wanted to disable the passive/automatic arming feature of the alarm. Sadly, it's not there. Does anyone know how to do it without going to the casa? Do it safely of course? I'd rather go to the casa than fumble with the alarm myself unless it's as simple as putting the alarm in valet mode. TIA.
    Oct 2008
    #5365
    Oct 2008
    #5366
    lesson learned: mind my own ms
  7. #5367
    [quote=fermontalban;1290860]Out of curiousity, how is the immobilizer enabled/disabled?
    HI sir,
    As i understand about immobilizer from my ex Audi A6, it was a chip embeded inside the car key...every time when you start the engine, the sensor will sense the chip inside the key...when the code is correct, it will not cut the engine...
    My experience was i use the spare key,made from outside store, it can start the engine, but it was cut off after 1 mins....so the the spare key sayang..
    #5368
    it's there . from the disarmed condition, turn the ignition to on position > press and hold the valet push-button switch for a few seconds or until the light becomes steady. rearming it, press and release the button switch anytime while the ignition is on.
    Apr 2006
    #5369
    I met up with sir ching earlier this morning at bigberts to discuss things about our club's planned roadtrip.. Further details will be discussed in this thread on the coming days..
    Sir ching thanks for bringing to your office & showing me your water vendo machines.. I had a great time sir
    thanks also for the lunch treat at the taiwanese resto
    #5370
    Hi Guys,
    After the ordeal of forced accessory purchase plus absorbing the price increase plus the month long wait plus the "false promises of having a unit ready but it was given to someone else due to a misunderstanding..."
    I think I will finally have my Monty delivered to me this coming Thursday... *keeps fingers crossed*... My question guys, if anyone would be kind enough to chime in is regarding the tint for my Sedona Red Monty...
    I asked for super black for the side and rear windows and a one piece medium black tint for the windshield... However, my SA is insisting that the "super black" tint costs more and I'll have to shell out more money as it is outside of their usual rate for dark tints... (As if I haven't shelled out enough money, tsk, tsk)
    I just want to get your opinion, for those who have had their Monty's tinted at the dealer prior to delivery if this is true or am I being fed another load of bullcr*p... (excuse the language)...
    Your advice would be really appreciated!
    Thanks in advance and I hope that I'm welcome to join the club once I get the Monty...
    Regards
  11. #5371
    Hi to all friends of Montero,
    I just have lunch EB with sir JPG, we plan to have our first road trip coming Sept, location shall be Baguio, the details will be provide by JPG this afternoon or tonight.....
    We really hope our friends here can provide more input to make our first road trip successful and wonderful one.....
    Thank you
  12. #5372
    Hi sir JPG, i thought you still on the way back, you told me your average speed in city was 5 KM per hour ????
    Please post the details na, many of our friends expecting. please sir.....
  13. #5373
    Quote Originally Posted by Pinoy Discus View Post
    Hi Guys,
    Regards
    Welcome to Montero thread, and please do join our EB and road trip....
    As for the tint, I have super black for all rear, for front and windscreen was Med black provided by casa free.......
    But now a day, maybe because of the high demand, the condition maybe change, please talk to you SA agin...
    May 2009
    #5374
    Immobilizer World: To all Montero Sprot Owners.. Thanks to XTO.
    [quote=XTO;1290593]
    Quote Originally Posted by Darwin_cd View Post
    honestly, i don't know if the 4X2 has it. sir you can e-mail the MMPC or ask your SA. but my magaling na SA texted me that my unit doesn't have it and if i wish to have one, it will cost less than 10K but when i e-mailed the MMPC, that was their reply
    Reply from MMPC / HARRY:
    From: "h-ilan*mitsubishi-motors.com.ph" <h-ilan*mitsubishi-motors.com.ph>
    To: Darwin Castro <darwin_cd*yahoo.com>
    Cc: d-doctor*mitsubishi-motors.com.ph; f-zafra*mitsubishi-motors.com.ph
    Sent: Tuesday, August 4, 2009 6:22:08 AM
    Subject: Re: Montero Sport 4x2 A/T Immobilizer?
    [SIZE=2]Dear Darwin,[/SIZE]
    [SIZE=2]Thank you for your follow up query regarding the immobilizer system and please find below our reply to your concern.[/SIZE]
    [SIZE=2]1. What about for MS 4x2 A/T? does it have engine immobilizer?[/SIZE]
    [SIZE=2]Yes, the New Mitsubishi Montero Sports 4X2 AT is also equipped with immobilizer system.[/SIZE]
    [SIZE=2]2. Whats the purpose of the immobilizer? [/SIZE]
    [SIZE=2]The purpose of the immobilizer is to prevent the engine from starting the vehicle if a key other than the key which is registered for the vehicle is used after an attemp to start the vehicle after force entry.[/SIZE]
    [SIZE=2]Where it was installed and located?[/SIZE]
    [SIZE=2]The immobilizer is located and installed in the ignition key cylinder.[/SIZE]
    [SIZE=2]3. How it will function / its work?[/SIZE]
    [SIZE=2]The immobilizer works when the ignition key is turned ON. The registered ignition key transmits its own key ID via radio wave. Tthe immobilizer controls the vehicle starting sytem to function when the sent key ID agrees with the pre-registered one. Two ignition keys are provided, and up to eight keys can be registered to one vehicle as needed.[/SIZE]
    [SIZE=2]4. How to test the immobilizer on MS 4x2 A/T unit?[/SIZE]
    [SIZE=2]Vehicle with immobilizer system will not start using an unregistered key.[/SIZE]
    [SIZE=2]We hope that the above have adressed your concern and thank you very much for visiting our website.[/SIZE]
    [SIZE=2]Sincerely,[/SIZE]
    [SIZE=2]
    [/SIZE]
    Sincerely,
    HARRY B. ILAN
    Customer Service Department
    Mitsubishi Motor Philippines Corporation
    Ortigas Ext., Cainta Rizal
    Tel. No. 658-0719, 658-0106 loc. 236
  15. #5375
    [quote=Darwin_cd;1290992]Immobilizer World: To all Montero Sprot Owners.. Thanks to XTO.
    [SIZE=2]
    [/SIZE]
    Sincerely,
    HARRY B. ILAN
    Outstanding sir Darwin, you do allot of home work....
    Thank you for the answer, and hope our friends here, dont sayang the money for extra spare key like me before...hahaha
    #5376
    Quote Originally Posted by chng238 View Post
    Thanks Sir Chng238 for the kind reply... I'm trying to convince my SA to give me the same deal because I had waived the visor already as it is part of the accessory package which I had already paid for...
    Wish me luck and I appreciate the warm welcome.
    I look forward to joining the club's EB's and road trips in the future...
    Kind regards
    Apr 2006
    #5377
    Hi Guys,
    Regards
    Yes sir they ask for extra charge if you choose "super black" , Free tint only applies for the medium black on side/rear windows & visor .. I had my windshield tinted 1 piece at winterpine..
    You're most welcome to join MSCP .. Enjoy your monty :thumbup:
    Thank you
    Hopefully we'll have an EB this month to discuss things with other members about our roadtrip to baguio on sept.. To be discussed are places to go in between stops going to baguio like in tarlac or pangasinan.. Any more ideas guys, nothings final pa naman eh..
    Jun 2005
    #5378
    xto sir...i believe the first procedure you stated puts the alarm in valet mode, not for disabling the passive arming feature. done this so many times already whenever i wash my monty coz of the repeated opening/closing of doors or whenever i have it detailed
    #5379
    Sir JPG111,
    Thanks for the response... Hmmm, okay I'll keep that in mind if my Jedi mind tricks won't work on my SA...
    That long road trip sounds really good, hehe...
    Kind regards
  20. #5380
    Kind regards
    All the best to you, we really like to see you on our EB and road trip.....
    Please also read the thread post by JPG111, he have different treatment from me.......
