Page 146 of 470 FirstFirst ... 4696136142143144145146147148149150156196246 ... LastLast
Results 2,901 to 2,920 of 9388
    #2901
    he's based in angeles but he always comes here in manila..I met the guy, he's nice & accomodating.. No problem the way he installed my 3 sets of HID's..He had installed his HID brands to a lot of Montero Sport's as you can see on his gallery aside from the other MS he installed last year.. I've been using my HID's for 6 months already, Ive even used it on a stormy weather 7 hour long drive but never encountered any moisture on my headlights & fog lamps..
    He was the one also who recommended that i use 6000K's on hi/lo beam for better visibilty during long drive..3000K for fog lights para di hirap during rainy/foggy weather..
    sir JPG111,
    magkano inabot lahat yung hi, lo & fog lights HID mo? paki pm naman yung name at contact number ng supplier. thanks...
    best regards,
    howie
    Aug 2008
    #2902
    mayor, pareho lang pala ng bulb ang reverse light and signal light sa front... I changed all my signal lights to white, and I used the same brand...
    question lang sir, how did you change the bulb for the reverse light?
    Oct 2003
    #2903
    Quote Originally Posted by migs0624 View Post
    I suggest you get the 22s na. I've tried fitting the 20s na chrome.
    no offense sa mga naka 20s dito, pero medyo bitin sya talaga.
    pero 20s na hindi chrome, siguro ok lang.
    but if chrome's talaga gusto mo. get the 22s or better yet 24s
    20s prep 100-120k
    22s prep 150-200k
    24s i have no idea, cant afford these
    those are black rhino with nitto tires.
    hope this helps you out man. good luck.
    sir migs,
    thanks for the info. saan shop po ba ang recommended na maraming mapagpipilian na rims? i may be staying a day or two in manila before heading home, so i need to be precise where to go and save time.
    Apr 2009
    #2904
    Quote Originally Posted by WenG2 View Post
    sir migs,
    sa greenhills. wheel gallery.
    Aug 2008
    #2905
    Are you sure its only 24 watts?, go check it again..
    Di nakakasilaw not because the HID's are not bright but because the projectors are well pointed & focused on the road..Im satisfied with the kind of brand i installed.. I dont see it as for looks only coz the HID's i choose really serves its purpose & not just for those " pasikat " on the road.. And im sure my HID's can also light up what the expensive brands can do..Kanya kanyang choice lng yan fanboi :badboy:
    I also installed LXSUN in my MS, 8000k low beam and 6000k fogs... i've been using it for 5 months now.. so far i have no complaints... also, i haven't experienced another car on the other side of the road flashing his lights because of the glare from my HIDs...
    Apr 2006
    #2906
    Quote Originally Posted by gabrcri View Post
    sir its easy to change the bulb of the reverse light, dukutin mo lang sa back part ng reverse lens sa bumper
    May 2009
    #2907
    hi,
    i am about to get a montero sport 4x2, my concern is will the 2.5 engine be some what under power? and another one is the resale value. I haven't seen this brought up this in thread so far.
    thanks.
    Oct 2007
    #2908
    sir kasama ba manual ng Code Alarm mo? if model CSI-300 nasa page 6.
    1. From the disarmed condition, turn the ignition key to the on position.
    2. Press and hold the valet push-button switch until the das mounted LED turns on. The LED will remain on as long as the system is in valet mode.
    3. To return to normal operation, press and release the push button switch anytime the ignition is on.
    thanks sir XTO. yes the manual is included and i've read it pero which one is the valet button switch? my remote has 4 buttons... the lock, unlock, trunk, and the asterisk. am i missing another button? pardon my ignorance hehehe.
    Oct 2007
    #2909
    hi! another inquiry po... is it possible to install a rear foglamp on my 4x2? how much would it cost and where? thank you!
    #2910
    Quote Originally Posted by Howie View Post
    sir JPG111,
    best regards,
    howie
    salamat po sa info sir JPG111....
    best regards,
    howie
    #2911
    Quote Originally Posted by kurdt View Post
    hi,
    thanks.
    hi kurdt,
    there are a couple of testimonials already about the power of the 2.5L, 4x2, you just need to read a few pages back. 2.5L, 4x2 din ang unit ko and i must say na it's quite strong. i tested na ibitin sa mga steep slope dito sa amin sa bulacan and i mean really steep, swabe naman ang recovery. overtaking is not a concern at all. but you also need to ask yourself how you will be using the unit? if your the rugged type and your driving terrain is very challenging or you simply want to have a feel of power, i suggest that you go for the 3.2L, 4x4. pero kung city driving and for family use lang, for me ok na yung 2.5L, 4x2.
    about the resale value naman, i considered that also before i bought my unit, but since it's new in the market wala pang makapag-advise. so what i did is compare it to the pajero, since they fall under the same category. the last time i check, a 1994 pajero is still going for about 900k to 1M. 40 to 50% depreciation in 5 years, hindi na masama yun.
    i hope this helps...
    cheers,
    howie
    #2912
    Quote Originally Posted by sag0 View Post
    not sure where they put it in the 4X2 but i think same lang. valet switch is the blue LED blinking sir. indicator and switch in one. you can push it anytime hehe.
    try to call CASA sir i think you can buy those yun nga lang baka by order pa kasi exclusive yan for GLS-SE like ng kila sir JPG111
    Oct 2007
    #2913
    oh wow!!! napipindot pala yun hahaha... yup sa 4x2 it's located near the key slot. ngayon ko lang tinry pindutin. many many thanks to you sir and to this thread i'm learning a lot.
    May 2009
    #2914
    hi kurdt,
    cheers,
    howie
    hi howie,
    thanks for your opinion, I guess the 2.5 will be enough for me. I hope you're right about the resale value
    Guys any opinion on the re-sales value?
    cheers!
    Jan 2009
    #2915
    Mga Sir question lang po bout behavior of H.I.D I installed 6000k on my low last nyt every tym I open my low parang mahina ung light then after 2 second nagiging bright na is that a nornal behavior? TIA God is good!
    Apr 2006
    #2916
    Quote Originally Posted by djin_xxx View Post
    Normal talaga yan sa HID.. what brand have you installed?
    Jan 2009
    #2917
    I installed Xenon headlamps bought it from a friend slim ballast ung kinuha ko. tnx sir JPG111 for always answering my questions.
    #2918
    hi! may concern lang po ako regarding sa alarm...
    bakit pag pinatay ko yung engine then bumaba ako ng sasakyan ng hindi ko nilolock, pag after one minute binuksan ko ulit yung doors tumutunog yung alarm? is there any way para ma-adjust ito? thanks po.
    Sir, pede po i-configure yan. Pede nyo i check sa manual (Separate ung manual ng code alarm since dito na sa atin kinakabit yan) or pinaka-safe e dalhin sa CASA -Accessories Section. May nakasabay na ako sa Citimotors Makati na pina enable nya ung auto lock. Ako kse I prefer yung auto arm lang. May history na kse ako ng nakaiwan ng susi
    yung regarding po sa alarm...
    nakakairita lang kunyari nagpapa carwash ka tapos you close the doors but leave it unlocked syempre. then pag bubuksan na nila to clean the interior, ayun mag aalarm na... and i always have to press the remote para mamatay yung alarm.
    May valet mode po yung alarm natin. Turn on the key ignition -> press the blue button/light for 3 seconds, pag nag steady na ung ilaw. valet mode na sya. To turn off valet mode, Turn on the key ignition -> push the blue button/light.
    Aug 2005
    #2919
    you mean stock rims?
    6 x 139, 17 x 7.5j
    265/65/17. offset di ko pa sure yung sa stock bro hehe
    Sir migs,
    Thanks for the prompt reply. So to cut things short sir, all i need to say when sourcing out for new shoes for my MS is if they have 6 x 139 wheels and i'm ready to go, whether in banawe or discount stores in the US or anywhere for that matter?
    Jan 2009
    #2920
    *JPG111, sir where can I buy the Hybrid super white bulb? thanks!
