Results 1 to 10 of 3921
- Feb 2013
- 6
February 4th, 2013 09:38 AM #1I just got my Montero Sport GLX 2.5 Non-VGT AT vehicle. There are a lot of positive sides but one negative side is that it seems to lose power when negotiating an uphill specially if your coming from a full stop. It sometimes feel that it would die on me.
Anyone ever experience this before? Appreciate sharing your experience.
- Jul 2009
- 153
February 8th, 2013 09:53 AM #2Ever tried a Ford Ranger Trekker? Kahit fully loaded ako ng pasahero sa loob at upon din ng gamit yung bed parang walang karga pag umaakyat ako ng Baguio, umo-overtake pa kamo, lalo na pag nag engage yung turbo talagang walang sasantohin. Lasenggero ng lang sa diesel hehehe!
- Feb 2013
- 51
February 27th, 2013 09:44 PM #3sir i think nasa pag drive lang yan...
ako kc hataw naman kahit full stop ako then aakyat..
ask ko lang ung psi mo sa lahat ng tires..???ako kc 40 sa lahat kami lang 4 my family k naman xa..
FC pala ng GLX mo...??
- Feb 2013
- 51
February 27th, 2013 09:46 PM #4ung GLX natin need ba ng turbo timer or not..
how true na kahit patayin mo agad ang makita basta di naman daw long distance oky lang daw.. how true..
- Oct 2012
- 105
February 27th, 2013 10:12 PM #5
February 27th, 2013 10:55 PM #6
February 27th, 2013 11:01 PM #7
If you have a problem with uphills, chances are that you're simply using the wrong gear.
Our 1991 Mitsubishi L200 with the same 4D56 engine but no VGT nor turbo (ergo, makes only 70 bhp and probably 50 whp) has no problem with steep inclines, as long as you keep it in first gear.
February 28th, 2013 12:44 AM #8
The dreaded turbo lag on a non-vgt. Medyo bitin talaga yan kung nasa gitna ka na ng uphill from a full stop kaya mainam na i-lagay mo yung matic shifter sa lowest gear limit then buwelo para pag umabot ka sa paahon eh nasa tamang rpm range yung engine.
At what rpm ba nag eengage ang turbo ng non-vgt?
March 24th, 2013 12:05 AM #9
Uy a specific thread for non- vgt, like!
Just got mine last Thursday, Savannah white, 2013 GLX AT. I will be writing my FR once I use it on slex or nlex.
First thing to do is activate the GPS. I already tried taking off the HU cover & hindi naman pala mahirap, medyo ingat lang sa pagsungkit. Problema lang is yung pagkopya ng software from other sd, then update sa ver 2.3.
Sino na sa inyo nakapag-activate ng gps? Pakopya naman?Last edited by bogart; March 24th, 2013 at 12:08 AM.
- Jun 2009
- 17
March 24th, 2013 03:09 PM #10At what rpm ba nag eengage ang turbo ng non-vgt?[/QUOTE]
Guys, follow up questions for 2.5 non vgt owners...
Roadstar is reliable.
Finding the Best Tire for You
