wow sir zix888! Ang dami nyan! Thats 480 thousand kms let say 10kms ang gamit per piece...nanghihinayang tuloy ako sa binenta kong bd28 kay sir Ry-tower...ngayon wala na akong stock! Balik Bosch nalang ako...![]()
Guys, Im due for 5k PMS na, currently *4800km. Just curious, yung next 5k PMS ko ba is based sa ODO or once nasa 6k kms na ako, since I had my first 1k PMS naman, so technically, parang 4k kms palang tinakbo pagpatak ng 5k ODO.
Just had my 40k PMS at Diamond motors (A/T 4x2)
Labor . . 3,686.58
7 oil (multigrade). . 1,470
Oil filter (oem replacement). . 350
Fuel filter (Fujiyama). .850
ATF dexron III (10ltrs)...2,000
Coolant (8.2 ltrs) - 3ltrs concentrate coolant at 6ltrs distilled h2O........300
Brake fluid......220
Air filter (oem replacement)...330
2 rear shocks replaced......FREE (under warranty-mechanic recommended it to SA for replacement)
Tip sa mechanic .....350
Tyre rotation including the spare
Disc/drum brake cleaning....no need for replacement ang brake pads since makapal pa ang pads
Drain ang mag fluids ng radiator/radiator reservoir/tranny/brakes
May natira pang 1ltr coolant concentrate at brake fluid
Mechanic recommend aircon cleaning next pms
Rear differential oil bago pa kaya Hindi ko pinapaltan nun binuksan un rear axle.
7am pinasok - 330pm out
Mechanic tinatawag ako bago idrain/iopen at paltan ang dapat paltan
One happy customer here of diamond motors![]()
Yung PMS warning ko for 1K nag prompt lang kanikanina... but yung Odo reading ko is 800km pa lang. Is it normal? o dapat by the time na ma-hit ko yung 1000km tsaka pa lang mag warning?
hi sir zix, casa used 7li in all my oil changes. i had oil changes during kms 1k (mineral?), 5k (7li Turbo XP), 10k (7li Turbo XP), 20k (7li Delo 400), and lately 30k (7 quarts RP oil < 7li). i should have saved almost 2.5li if 6.5li lang ang kada lagaypero ok din na 7li nailagay kasi walang naiiwan kada change oil, so far wala naman akong naramdaman na masamang naging epekto sa makina in case sobra man ang karga.
btw, may available ka pa ba na BD28 sir? di ko pa naman need now, katatapos lang ng 30k pms ko, mga bandang Jun/Jul siguro. i have 2 extra BD7028 pero ayaw gamitin ng casa kasi mas malaki daw kesa sa BD28![]()
Ganyan din sakin sir i guess its normal para ma warn ka na ng maaga. Although ako mukhang lalagpas pa ng 1.4k bago ko mapa 1k pms kasi taga-batangas ako.
Sent from my GT-S7562 using Tapatalk 2
Mga sir, pa update naman kung saang casa nag-a allow na magdala ng sariling oil. Nearing 1k PMS already. Ang mahal sa citimotors makati abutin daw ng P6,200 just for the 1k PMS.![]()
