Page 62 of 106 FirstFirst ... 125258596061626364656672 ... LastLast
Results 1,221 to 1,240 of 3240
    Jun 2011
    Quote Originally Posted by zix888 View Post
    pm sent sir. thanks
    Pa pm din pa sir zix.tnx
    80k pms
    with TLC from zix
    Quote Originally Posted by epb888 View Post
    Sir zix888 pa pm din ako 2013 sta fe 3 at 2014 accent HB diesel ang unit ko. OCC and EGR blanking plate how much and location pls.. thanks..
    pm sent sir. thanks. see u soon
    Pm sent sir zix, due na 15k pms unit ng tatay ko
    Quote Originally Posted by kaioz View Post
    pm sent sir, thanks. see u soon
    May 2009
    sir zix, pm sent. monty is due for 35k pms.
    Posted via Tsikot Mobile App
    joknoll
    *ZIX
    40K PMS
    plus occ draining
    ac filter cleaning
    greasing
    brake pads replace
    Feb 2014
    joknoll
    *ZIX
    40K PMS
    plus occ draining
    ac filter cleaning
    greasing
    brake pads replace
    [IMG]http://i1085.photobucket.com/albums/j432/sss44ph/0F52306B-2093-
    4AA0-8755-DFA79E96B8E6_zpsorffw3tc.jpg[/IMG]
    Thanks Zix for the 40k PMS!
    High quality oils and fluids (mobil TDT, Castrol) and parts used (Baldwin filters, Tokico brake pads) but priced lower compared to casa, plus quality and thorough workmanship care of Zix and his mechanic.
    Satisfied customer here.
    Sep 2012
    Good day mga sir, itatanong ko lng sana kung pareho lng ba ang genuine oil filter ng montero sa pinas at pajero sport sa saudi? Mura kac mga genuine parts d2 balak ko sana magdala paguwi ko,.TIA
    Quote Originally Posted by aldrincoronel View Post
    If same engine, then the answer is yes. Hoard ka na. hehe
    Mar 2015
    Hi sir zix new member ako nagbabasa basa ako at gusto na namin ilabas sa casa yung kotse starting 15k pms. Question lang, full maintenance ba kayo gumawa sir as in parang sa casa din pati specific procedures every certain pms? Thank you pa pm po.
    Add ko lang pala kahapon biglang nag on yung check engine lamp so dadalhin ko sa casa mamaya yung monty. Pag ganitong situation na under your care sir paano kaya? Mawalan na sigurado ako ng warranty sa casa once na inilabas ko na diba? Maraming salamat po.
    Jul 2010
    Quote Originally Posted by wils0n15 View Post
    Dalhin mo muna sa casa under warranty pa naman yan. Most probably, marumi na yung fuel filter mo. Not sure kung covered yan ng warranty. I could be wrong though.
    Apr 2015
    Sir Zix sent you a pm regarding 10k PMS. Thanks.
    Mar 2015
    Quote Originally Posted by boytsiks View Post
    Ok salamat sir. Nasa 13k na kasi odo ko ngayon so maganda maayos muna nila under warranty bago ko ilabas sa casa for 15k pms.
    dalhin mo sa shop for free scan. a monty owner went to the shop yesterday, sabi daw sa casa scv problem, gusto palitan agad. actual scan showed egr valve, double gastos gusto gawin sa kanya. para may idea ka na what really caused the CEL, hindi ka na pwede paikutin if ever man gusto mo pa ipa casa.
    pm sent, kindly check. thanks
    Mar 2015
    Ok na po mga sir fuel filter nga problema dahil madumi daw kinakarga ko sa petron kahit yung napakamahal na turbo diesel. So bumili muna ako ng filter sa mitsuprime pero yung warning nandun parin ang sabi sakin idrive ko lang daw para mag reset, o hindi lang sila marunong mag reset?
    ^fuel filter cartrige ba yan? hindi ko lang alam if same ba procedure sa toyota. unplug mo yung wire sa ibabaw ng filter case, then ON mo yung sasakyan without starting, plug mo ulit yung wire within 3-60 seconds para mawala warning light.
    Aug 2005
    Marami na sir negative feedback sa petron diesel dito sa forum esp dito sa montero threads. Bago pa nga monty nung iba nag lit na cel warning. Yung sa kin inabot ng 20k km pero di naman nag cel until mapalitan na ni sir zix yung filter. Btw I'm using unioil since 1k km up to present
    Oct 2014
    Quote Originally Posted by leinahtan View Post
    i agree. i usually put seaoil or caltex or shell fuel save. nung ng karga ako last time ng petron notice ko n biglang itim oil ko. i reverted back to seaoil and or caltex ngligthen un oil ko.
    i don't why ganun sa petron but after that experience d n ako magpetron diesel. unless wla n talaga choice.
    Jun 2012
    Petron diesel maxx kami. Yung pinakamura. Nagcel nung mga 18-19k km. Since then kada 10k km na lang magpalit
Montero Sport PMS Thread
