Hindi ko nga alam kung bakit nilalagay ng Shell na for indirect and direct injection, turbocharged and egr installed engines eh puwede yang CF rated oil nila. Dapat kasi CI-4 man lang para kaya yung addt'l sot ng egr. Sa tingin ko namamahalan na Shell mag-apply pa sa API at tiwala na lang sila na tutal eh napapatunayan namang kaya ng oils nila yung 5,000kms OCI.
Tignan mo Shell R3, CH rated lang but yung prodct sheet niya comparable sa Ci-4 rated na Delo Gold Ultra.
Baka cost cutting lang talaga. Mahal kasi mag-pa-approve sa API.
Fasten your seatbelt! Or else...Driven To Thrill!
and majority na nagpapa-change oil, hindi parin tinitignan yung API rating. kaya siguro hindi na nila na-update
Sirs;
Had my GLSV's 15t km PMS May 2nd sa Carworld Subic:
Oil filter P932
7L Turbo XP P3875
Diesel Smoke Stop...? P441
Anti Rust Penetrant...? P535
Misc P300
Total P7270
:fyi: Technician (for GPS update) attendance on this certain casa is every Wednesdays 11am to 2pm.
Just sharing
just had my 40,000 PMS yesterday at Citimotors ( Makati )
Engine Flush/ E. Protector/ DSL Treatment - 1,197
ATF (Dextron) - 3,799.77
Brake Cleaner/ Fluid - 519.16
Coolant - 1,064.08
7 ltr Fully Synthetic Oil - 4,612.50
Oil Filter - 1,042.72
Air Cleaner - 2,079.84
Rod Antenna (Nabali ) - 661.92
Gasket Oil Drain - 41.44
Other charges - 473.3
Labor - 3,780.80
Total - 19,272.53
my SA told me that on my 45k PMS I need to have a general aircon cleaning for 19,500
can anyone verify these?
thanks
Pass muna kayo diyan, sa 19500 para ka na nagpalit ng bagong evaporator and compressor, might as well wait for any part to break down. Maminimize pa pati removal ng mga panels covering the a/c parts. Kabit na lang kayo cabin filter, tapos yun na lang palitan ninyo every year
may mga naka bendix brake pads na po ba sa inyo? kamusta yung preno? need na kasi paltan yung front pads ng monty gls se namin , sa casa 6k eh sa suking auto supply 960 lang yung bendix
our manual specifies the viscosity (most motor oils conventional or synthetic, fit this, e.g. shell helix hx5 yellow and up), it specifies an API CD OR HIGHER rating (the shell hx 5 has a CF rating which is higher). the ACEA rating recommendation for our Monty is A1/B1 A3/B3 A3/B4 or A5/B5 which is the rating for the synthetic oils. the way it was written (i think is an OR option) which means you can use the API or ACEA rating. The 2 are not equivalent, the API CD is an older "more lenient" grade which allows the regular yellow helix to be included.
most websites do not say use synthetic over regular, but recommend oem/manufacturer's recommendation for their vehicles.
i am still awaiting reply to my email query to mitsubishi motors about this. hope this confuses us more........
Hi guys,
Where can I have the aircon filter installed sa Alabang area? How much is it? Can any aircon tech install it?
Thank you
Sir meron sa MSCP, you can contact Aldrich at 09223711377. Installation is easy and can be DIY'ed. ;)Originally Posted by Jesto
19,500 pesos in my opinion is too pricey.... If you have installed aircon cabin filter much earlier, maybe aircon cleaning or specifically the evaporator does not need an immediate inspection and cleaning.... beside sir, if you have clogged or dirt accumulated problem with your evaporator, medyo restricted na rin po ang buga ng hangin and you can notice it..... Anyway, try to visit and read the posts in MSCP forum, one lady montero owner there have her aircon serviced/reconditioned, she just only paid 3,500 pesos including the supply and installation of aircon cabin filter... hope this helps..
zix, yung AVES sikat na aircon shop. though this is in QC area.
http://tsikot.com/forums/aircon-temp...in-pala-87274/
Master zix888 along j.aguilar ave.casimiro Cooldrive ok po sila gumawa.kung papagawa po kayo pasyalan ko kayo sir hehe.shops owner is roland8287405
Thanks cb and silverV for the reply. Actually tropa yung nagpapatanong, eh sabi ko wala ako alam sa area na yun kasi sa kabilang dulo yung area ko.
