Page 126 of 324 FirstFirst ... 2676116122123124125126127128129130136176226 ... LastLast
Results 1,251 to 1,260 of 3240
    Sep 2011
    #1251
    Kaka change oil ko lang din nang amin.
    Yung bagong filter (yung updated version with the different part number) nabili ko ng 900 pesos lang, almost same price sa lumang model.
    #1252
    due for another round of pms sched this week. ang bilis ng 5k lumipas. medyo nagsasawa na ko kakapunta sa casa :puke1:
    Feb 2012
    #1253
    Im nearing 20k pms. Balak ko ng mag pa pms outside medyo d ako satisfied at sa mahal ng cost sa casa. What are the things to do on 20k pms? Sorry tamad mag backread:D
    Sent from my GT-I9082 using Tapatalk 2
    Jun 2009
    #1254
    Quote Originally Posted by rap2_tan View Post
    It's in our service booklet sir, lahat po ng PMS procedures nakalagay po lahat dun
    Feb 2007
    #1255
    http://www.diamond-motor.com.ph/index.php/service
    HEAVY CHECK UP
    Operations after engine is warmed up
    Change engine oil and oil filter
    Check / adjust valve clearance (except for vehicles with auto-lash adjusters)
    Check / adjust basic ignition timing (petrol powered vehicles)
    Check / adjust basic ignition timing (diesel powered vehicles)
    Check / adjust basic idling speed and CO concentration (petrol powered vehicles)
    Check choke mechanism and linkage
    Check crankcase ventilation hoses (petrol powered vehicles)
    Check gas recirculating system (petrol powered vehicles)
    Check body condition for damages (underbody coating and body paint for corrosion damages)
    Check cooling system for leaks
    Check fuel system clamp for looseness and damages
    Operations inside the engine compartment
    Check V-belts for cracks, fraying wear and adjust tension
    Check condition of distributor contact points
    Check condition of distributor spark advancer
    Replace contact point and condenser
    Check ignition cables for damages
    Check vacuum pump oil hoses for damages (diesel powered vehicles)
    Check intake air and turbocharger oil hoses for damage (vehicles with turbo charger)
    Check operation of crankcase emission control system (petrol powered vehicles)
    Replace spark plugs (petrol powered vehicles)
    Inspect condition of fuel injectors
    Check radiator hoses for damages and proper connection
    Check / clean condition of throttle body
    Replace air cleaner element
    Check fluid level in automatic transmission (including transfer)
    Replace fuel filter
    Check engine coolant condition and level
    Check brake / clutch fluid and power steering fluid level and condition
    Check / adjust brake pedal and clutch pedal for free play
    Check / top up battery electrolyte level and terminals for loose connections / corrosion; check battery clamp
    Operations under the vehicle
    Check suspension sytem for looseness and damages
    Check suspension arm ball joints for play and dust covers for damages
    Lubricate suspension arm, steering linkage and propeller shaft with grease fitting
    Check drive shaft boots for damages
    Check steering linkage for damages and loose connections (including seals and boots)
    Check gear oil level in manual transmission (including transfer case)
    Check gear oil level in front and rear axles
    Check exhaust pipe connection / installation for gas leakages or damages
    Tighten underchassis bolts / nuts
    Check / adjust parking brake stroke and play
    Operations outside the vehicle
    Rotate tires
    Check brake hoses and pipes for leakages
    Check / clean brake pads, shoe linings, discs for wear, brake and drums for wear
    Check fuel hoses and pipes for leakages
    Check tire wear, tread depth, inflation pressure, center cap and tire valve cap
    Check windshield wiper nozzle and wiper blade
    Electrical Operations
    Check condition and function of all exterior lamps
    Check condition and function of all interior lamps
    Check instrument panel lamp
    Check all instrument panel meters and gauges
    Check funtion of all power windows, power mirrors and power door locks
    Check front / rear wipers in all ranges
    Check horn
    Check warning buzzer
    Check power antenna
    APPLICABLE ONLY EVERY 40,000 KMS
    Replace engine coolant
    Change automatic transmission fluid (including transfer) and replace automatic transmission internal/external filter
    Change brake / clutch fluid and power steering fluid
    RECOMMENDED BETWEEN 60,000 KMS and 80,000 KMS
    Replace engine timing belt (except vehicles with timing chain)
    RECOMMENDED EVERY 20,000 KMS
    Clean fuel injectors (petrol powered engines)
    Sent from my iPad using Tsikot Car Forums
    #1256
    nagpapa-engine flushing kayo every time change oil time? sa gas car ko kasi matagal ko na 'to tinigil kasi nabasa ko na hindi naman talaga beneficial sa mga engines na malayo na din narating
    May 2013
    #1257
    ask ko lang mga sir, gumamit ako ng MOBIL TDT nung 1000pms, Now mag 5k na sya pero sobra laput na nung oil, pero fully synthetic naman nakalagay dun sa mobil 1. normal lang po ba uN? parang gusto ko tuloy pa change oil uli ng 5k imbes na top up lang. ty.
    Feb 2014
    #1258
    Hi guys, new owner of ms glx 2014 here. Ask ko lang how much ang air cabin filter and installation?
    Feb 2007
    #1259
    Quote Originally Posted by davejitsu View Post
    Send zix888 a pm sir;)
    Posted via Tsikot Mobile App
    Feb 2014
    #1260
    *zix888, pm sent sir!
Montero Sport PMS Thread
