Mostly nga po sa aircon tubes yan, although sa sedan ko naranasan yan maulan din panahun, upon checking nakita ko mga aircon tubes nag moist talaga.
Yes boss umuulan and slightly foggy. Normal lang yun? Nothing to worry about? Thankyou!
Sent from my SM-N9208 using Tsikot Forums mobile app
Hi Pajero Fieldmasters,
Plano ko bumili ng FM, yung nakikita ko na medyo ok usually ang description is Pajero FM 2006, Automatic, 4x4, ano kaya dapat kong coconsider na papacheck, and ano masabi nyo sa ganitong FM. Di ba mahirap mag hanap ng pyesa, of course considering second hand. Pa advise naman mga masters. Thanks
Better po bring your mechanic ung xpert, kasi madamika need i check sa pajero since its 2nd hand. Turbo, engine,pang ilalim aircon, if pyesa po need nyu wala naman problema, chaka matibay yan promise basta maalaga ang previous owner. Ung samin dti 99 model na field master walaman naging problem kundi aircon compressor lang, kulang 200k mileage ng mabenta namin. Mahal lang pala gulong nya, hahaha
And be careful pala check the papers properly since madami din hot na pajero, and stay away sa mga conversion..
thank you sir for that info im a newbie and i cant seem to post in a seperate thread only reply , i have a 2001 fieldmaster local unit , umiilaw yung oil pressure indicator kaka change oil ko lang at nun chineck ko yung oil hindi naman nasa dangerous level , tpos umiilaw sya intermittent namamatay sindi, pag inapakan ko yung accelerator nagbblink pag binatawan ko nawawala pasulpot sulpot any help will be appreciated i hope oil pressure sensor lang may problema since almost 16 years na yun pajero.
Better po dalhin mo s mechanic ipa scan mo sa obd nila pAra makita saan ung error, could be nothing and reset lang nila but could be alarming na malaking gastus pAla ang nakaabang. Hehe
I think nothing to worry as long na walang nagbabago sa performance ng pajero nyo. Ung samin nun 1998 hangang nabenga 2 years ago aircon compressor and timing belt lang ang napalitan pati pala mga gulong na ubod ng mahal. Hehe
bale yung sa lube station naglagay isang malaki na container ng delo gold ubos tpos almost half nun 1 liter nalagay. after two weeks when i checked medyo dark na agad yung langis hindi naman sya nagagamit madalas dadalhin ko s casa papacheck ko mahirap mang hula mamaya bumili ako ng oil pressure sensor tpos hindi pla yun ang culprit pero sana yun nga ang may problema kesa makina.
bili ka na lang din ng oil pressure switch. napakamura lang naman. meron kang mabibili na tipong P70 lamang. circuit brand.
yung sa sasakyan ko pinalitan ko lang nung december nung oil switch dahil dun pala nanggagaling ang oil leak
pero ipacheck mo na lang din ang oil pressure gamit ang mechanical oil pressure gage sa service center para tama ang diagnosis.
Hi, I have a question sa mga owners ng Pajero FM.
Does it have a (ready) transfer case and front differential?
Like in the case of the Nissan Patrol Y61 4x2 wherein you can buy a kit and install it for 4x4 applications.
TIA.![]()
^nope. Not as simple yung conversion unlike sa GQ and GU
Ah, ok. I think I know what you mean.
Patrol front suspension is live axle pala, compared to IFS for Pajero.
So there's a hollow void in the middle of the front suspension of a 4x2 FM, where the diff and axles are supposed to be, right?
How about the transmission of the FM 4x2? Straight forward ba? No transfer case?
I'm assuming here that you have an FM.
thanks for all the help guys , got my fm checked and it turns out may problema lang s oil pressure sensor whew, kala ko engine , one last question s mga fm fanatics dito meron ba kayong alam kung saan makakabili ng over rider para s fm natin brand new, and how much will it cost . thank you
i was about to dispose my field master, but i changed my mind.
Now, I'm going to have it repainted at Mitsubishi to have a color like this one -
