Page 688 of 718 FirstFirst ... 588638678684685686687688689690691692698 ... LastLast
Results 13,741 to 13,760 of 14348
    #13741
    Ok naman ang dating. Simple lang yung mags niya.
    Hindi nga siya halatang naka 18"
    Mar 2013
    #13742
    Mga bossing im planning to upgrade the turbo on FM.. im not sure kung ano turbo nya buy i think its a TD04..
    Ive been reading some reviews online and ang nakikita ko na napag cocompare palagi is
    TD04 vs TD04-09 and
    TD04 vs Rhf4 colorado turbo.
    Although a friend told me earlier na go for rhf4 colorado if im opting to upgrade.
    Can anyone enlighten me which is better among the three.. or if td04 nga ba talaga turbo ng fm ko hehe. Thanks!
    Sent from my SM-N9208 using Tsikot Forums mobile app
    Jan 2016
    #13743
    Pa tulong lang po sana sa inyo mga sir. Last month lang po pina calibrate tapos ngayon malakas po yung vibration sa engine (4M40) during idle.
    Pina check ko ulit sa mekaniko:
    ***nozzle==>ok
    ***injector===>ok
    ***injection pump ===>ok
    ***oil dipstick==> no sign of blow-by
    *** ka papalit lang po 2 engine support, transmission support at transfer case support
    Ganon pa rin ang problema. Ang ginawa nalang sa mekaniko, para ma less lang yung vibration sa engine, ina adjust niya yung pressure each nozzle. #1 =200; #2 = 160; #3 = 175; #4 = 160. Tinanong ko sa kanya, diba dapat balance yung pressure? sagot naman niya na wala na daw siya'ng makitang solusyon para ma lessen yung vibration sa engine during idle.
    Safe po ba yun sir? Saan kaya ang possibleng problema nito sir?
    Maraming salamat po sa inyo sir
    Mar 2013
    #13744
    Quote Originally Posted by Rsty View Post
    ***nozzle==>ok
    ***injector===>ok
    Dapat pareparehas yung number. Baka sira na tranny support mo. Tuwing kelan lang ba malakas vibrate
    Jun 2006
    #13745
    Mga bossing, san ako makakabili ng mud guard (rear tires) para sa 2005 Fieldmaster. Help naman baka may alam kau kung san makaka bili ng mura. Thanks.
    #13746
    ***nozzle==>ok
    ***injector===>ok
    Decarbonize engine?
    Any exhaust restrictions?
    Alternator or compressor bearings seized?
    Idle speed Too low ?
    Worst case, wrong injection timing
    Sent from my ASUS_T00J using Tsikot Forums mobile app
    #13747
    Quote Originally Posted by Yeo View Post
    Mga bossing im 8jplanning to upgrade the turbo on FM.. im not sure kung ano turbo nya buy i think its a TD04..
    TD04 vs TD04-09 and
    Back read ka, nailagay ko na yung pwedeng turbo sa FM.
    #13748
    ***nozzle==>ok
    ***injector===>ok
    Pa check mo yung injection pump mo sa Central Diesel sa QC.
    Mar 2013
    #13749
    Got it sir nelany.. yung binanggit mo na need pa na mods or palitan pag nag upgrade to bigger turbo. Ano ano po yun?
    Im itching to get the rhf4 colorado turbo.. dami ko din nabasa good reviews kasi.
    Thankyou
    Apr 2012
    #13750
    Thankyou
    beside the colorado turbo, some of our colleagues in montero club who had turbo replacements used the subaro wrx sti turbo, and along with ecutek remapping had 240whp and above outputs...
    #13751
    Pag nag upgrade, is everything bolt on?
    Apr 2012
    #13752
    no bro, they need to fabricate brackets and supports to fit the new turbo. then after, reflash na sa ecutek
    #13753
    Thankyou
    Fabricate ng bagong bracket kung ibang turbo ilalagay mo sa FM. Meron modified na turbo para sa Pajero na using bigger turbo cartridge na will give you more boost na no need ng bracket mod.
    #13754
    Old school pa ang FM so walang ecutek to map. It will undergo dyno tune pag ibang turbo ang ilalagay para sa gain.
    Mar 2013
    #13755
    What modified turbo is that boss nelany.. para ma check ko din.. bush parin yun? The colorado im talking about is a billet type na bearing na.
    Apr 2012
    #13756
    i see, wala pa nga palang reflash program para sa 4m40 ng FM. sa 4d56 nasa isip ko...
    Jun 2007
    #13757
    Hi Guys, I have some questions on my FM 2.5 year model '99 4x4 local. Bought the unit sometime in 2006. I noticed that its front suspension is always been a problem i.e always disaligned, replaced ball joints, tie rod ends, pitman arm, etc at least once every 2 years. I have been using 555 replacement parts, and original mitsubishi shock absorber with sensor. Question: Is this normal, based on your others experience? Which is better 555 replacement parts or Atlas (nakita ko lang sa FB, but no actual experience on Atlas replacement parts). Lastly can you please recommend reliable shop to fix my FM front suspension?
    #13758
    Try mo sa Wheelers in Nroxas Banawe. In the few years that i have owned a fieldmaster, wala akong pinagawa sa suspension at all. All oem parts pa. Greasing lang secret diyan. Do it every 6 months. Basta orig na 555 parts, should be ok. Never heard of atlas
    Jun 2007
    #13759
    Thanks CB. Ill check Wheelers
    #13760
    Quote Originally Posted by andrewbugs View Post
    ^curious lang sir, nagpapa greasing ka ba before?
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
