Page 686 of 718 FirstFirst ... 586636676682683684685686687688689690696 ... LastLast
Results 13,701 to 13,720 of 14348
    #13701
    Yup JM, 4M40 FM. Should be the same yung part number ng turbo mo since FM din yung sa iyo. Me leak na ba yung turbo mo? I read sa isang foreign forum masama daw pag excessive yung oil leak. You may not be able to turn off the engine and may run wild.
    thanks for posting the part number bro. i'm planning to replace mine. ok pa naman siya sa ngayon pero baka bumigay din sooner or later.
    #13702
    Quote Originally Posted by Juan Martinez View Post
    Just prepare yung repair kit for your turbo. Pag binaklas na yung turbo then you will know yung tear and wear niya. Its then when you will know that sooner or later kung mag papalit kana.
    #13703
    ano kaya explanation dyan bro at bakit mag "wild"?
    anyhow, di ko na masyado ginagamit si FM. pang display na lang talaga. I'm at the losing end kung ibenta ko. spent a little fortune na cguro ☺
    #13704
    It's too technical para ma digest yung explanation easily so did not bother to get the details. I'm browsing that time to see other possible turbo model that I can buy for my FM. It turns out that it will require mod if you will be using bigger turbo at mas randam mo daw yung turbo lag pag bigger turbo. Hindi na lang, use nalang yung model para sa FM para plug and play.
    #13705
    BK yung efi version na 4M40 yung nag wa-wild? Bka yung me nalagyan na sensor or something. Sir Td-04 pa rin ba yung inorder mo? And made in australia din?
    #13706
    Below yung description ng turbo na inorder ko sa Ebay. Speed up auto parts yung seller and the link below.
    TD04-12T/ TF035 Turbo Charger for Mitsubishi Pajero Delica 4M40
    TD4-12T/ TF35 Turbo Charger for Mitsubishi Pajero Delica 4M4 2.5 2.8L 49377- | eBay
    #13707
    Anybody know's the part number ng automatic antenna ng Pajero. Yung stalk (mast) lang.
    Salamat,
    Buong assembly pala binili mo sir hindi repair kit lang?
    #13709
    have your IP checked
    Salamat sir.
    #13710
    Agree pa check mo yung injection pump.
    Salamat sir.
    #13711
    *nelany Sir, if may facebook kayo better check the group page of pajero 4x4 philippines, may post dun regarding sa antennae, meron dun original at replacement nagpost 2 months ago nga lang yun.
    May 2009
    #13712
    tama po....run away diesel na kung nagkataon....
    ang gagamitin na nyang fuel is the oil leaking past the turbo seals as well as the piston rings.
    only way para mapatay yung makina is to choke the air intake.
    ganyan din problema ko dati sa 4d56 turbo ng dati kong pickup. kung minsan may whistle, kung minsan naman wala.
    kung tama ang alaala ko e nasa P7k and up yung unofficial quote (via pm) ni central diesel sa akin nun sa turbo repairs....kasama na ata yung balancing. was planning to DIY it before kaso yung balancing naman ang poproblemahin ko.
    pero hindi ko na tinuloy dahil binenta ko na sasakyan.
    #13713
    Nelany, hindi ba good opportunity na to upgrade turbo now hehe
    #13714
    Quote Originally Posted by sleeepy View Post
    Salamat, nakuha ko yung part number ng mast ng Pajero sa Ebay eseller sa UK. I will order later sa Ebay.
    #13715
    Quote Originally Posted by miked View Post
    Yung latest quote ng Central diesel ay 3K labor sa pag baklas ng turbo sa sasakyan at 5K sa labor. Sa iyo ang parts.
    So far wala na yung whistle niya. Nag fit in na siguro. Start ko lang narinig ng ibinalik yung turbo. Lahat naman ng position niya bago binaklas at naibalik so less yung mawala sa balancing.
    #13716
    Opportunity na mag upgrade ng sasakyan, hehehe.
    Nauna na nga naka pasko yung FM ko. Nadyan na yung pampalit niyang turbo.
    #13717
    Mga sir, 7L ba ang oil capacity ng 4d56T and 4m40 ng gen2 and 2.5 pajero?
    Nalimutan ko na ilan oil capacity ng pajero natin hehe
    #13718
    for my 4m40, yes, 7 liters.
    6ltrs sa 4D56, 7ltrs sa 4m40. At least an hour na drain timer yan ha para marami talaga mailabas.
    #13720
    Bakit CB me Pajero ka ulit? Hehehe
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
