Sir ry tower, kung dko na po i bleed, palitan ko na lng po ung fuel filter, mas ok?
^ sirs, thanks a lot for the replies. i checked my records I actually replaced an auxiliary fan, blower motor, and expansion valve last december 16, 2014. I need to have my condenser checked. thanks again.
Yes, mura lang naman eh.
Papaayos ko mamaya yung hose na yun. Makunat na siguro. hehe
May isang problem pa pajero ko, kapag hindi pa mainit makina (less than 5 mins warm-up) kapag bumiyahe ako namamatay makina. Pero once mag-start (medyo pahirapan pa) okay na ulit.
Searched the net and may nakita ako na same problem with me at simple lang daw solution. Engine oil stop leak.
FYI and perusal na lang. View topic - Injector pump tips and tricks | Delica Canada | Mitsubishi Van Club
Ask ko lang din, may synthetic na nga kaya na gasket maker? Yun ata ang matibay.
Sir, i have the same problem on my FM, pahirapan mag maintain ng idle pag bagong start madalas namamatay pa..kahit anung apak sa throttle pedal hindi umaakyat yun rev...temporary fix ko is pump ko a few times yun fuel pump before starting which lessens the problem of "unresponsive throttle"...already replaced fuel filter, glow plugs.. but same problem...nagiging ok lang din after more or less 5mins of dasal at sapalaran...
Check your fuel line from the tank to the fuel filter. Puwede din kasi maging cause yan nang idling problem kasi may hangin sa system. Sa akin kasi wala problem sa starting at hindi palpak idling rpm. Hindi ko pa na-try lagyan nang STP Engine stop leak yung fuel tank kasi half pa eh at may 2T oil pa yun. Paubos ko muna bago ko itry.
Btw: had the leaking idle actuator hose replaced. Fuel hose lang nabili ko, wala kagaya nung orig na medyo malambot. Hindi kasi pala kumukunat yung orig hose na pang-coolant.
Fasten your seatbelt! Or else...Driven To Thrill!
Mga sir, tanong ko lang sana kung ano oil filt number ng baldwin na pang pajero 96 4d56? Mga magkano kaya? May makukuhanan ba nito dito sa mutinlupa area? Thank you!
Mr. Swabe,, baka front oil seal ng injection pump mo kailangan ng palitan...lumulutong kasi yan pag matagal na kaya pumapasok ang hangin at engine oil sa injection pump..check mo fuel kung medyo maitim..ganyan din kasi nangyari sa fm ko tumatakbo bigla na lang namatay ang makina.
thanks for the replies..will go ahead and have those things checked out (fuel line and front oil seal on the injection pump) can anyone recommend a good shop around banawe QC who might be able to check on these? thanks again!
Yes puwede yan sa 4m40 but may mas malaki na BD7028 na pang-4m40 talaga kasi mas malaki naman talaga oil filter nito.
Kaso mas maganda daw filtration ability nang bd28 kaya yan ginagamit nang karamihan. hehe
Meron ba pwede mag share ng options ko sa Radiator replacement, nag canvass kasi ako sa casa 30k daw bnew oem, medyo mahal. Ano pa ba pwede replacement and saan nakakakuha. Evercool Ultima sana kung may nakaka alam.
May nabasa din ako sa previous threads na may nabibili yung plastic top sa Denso oem.
Alin ba ang Best option?? Last option ko sana yung papa tanso yung top.
Sa tingin ko na tuluyan yung Radiator ko kasi oem pa never touched since birth, nung ginawa yung Timing Chain ko. Dala narin ng Old age. Leaking sa sides ng plastic top.
Mas prefer ko sana bnew kung ok naman Price ng evercool.puro kalawang narin kasi yung loob ng Radiator ko kahit iflushing.
