i'm curious how were you able to identify that it was the wire. last time out, the aircon mechanic also noticed the hi pressure after coming through heavy traffic. pinalo yung aux fan, kasi parang tumigil nga.
Guys, may naririnig akong rattle (nginig) parang naiipit na brake ang sound sa may evaporator ko. i am sure its aircon related kasi during the sound pag pinapatay ko AC biglang wala. hindi naman sumasayad ang blower ko. its inside the casing. parang evaporator or sa expansion valve. Naririning ko lang sya pag sobrang lamig na sa loob at nag oon and off na ang manual thermostat ko. ano kaya ito? any similar experience with my problem ?
Salamat po![]()
hello mga owners, gusto ko sana i diy yung front speakers ko. tanong ko sana kung anong size ang puede kong ipalit na bolt on? mukhang hindi kakasya mga 6" na speakers. garalgal na kasi yung front passenger side.
Thank you
Didn't weigh mine.. Pero ironman estimated around 30-40kgs ang front bumper.. Medyo dumapa nga ulo ng FM ko when I installed the bumper.. Kaya I ordered ironman shocks na sabay adjust ng torsion bars nextweek.. FC was not affected sir.. Para ka lang nagsakay ng isang chicks.. Hehehe
Problema sira FM ko..Nagpa change oil ako kahapon sabay oil filter & air filter.. Drove it home tapos biglang medyo palyado after 5minutes of driving.. Inisip ko baka kulan lang ng bleeding yung fuel filter.. Ginamit ko kagabi, medyo palyado pa rin to the point na namatayan ako while slowing down.. Pero nakauwi naman ng house.. Tapos kanina palyado na talaga.. Kahit anong bleeding ko ng fuel filter palyado pa rin.. Pinainit ko to normal operating temp pero palyado pa rin.. Mekaniko na bahala nito bukas..
Sana minor like like a bad fuel filter or a leak somewhere.. Huwag lang sana injection pump.. It was running fine before the PMS..
Hahay
Mabigat pala talaga yun ARB bumpers. Regarding sa problem niyo sir, tanong ko lang, nakita niyo ba yun process kung paano nila ni-bleed yun injectors at napansin niyo ba kung gaano karami nilagay nilang diesel pang priming sa fuel filter ninyo? Don't worry sir at malabong injection pump pa ang problem ninyo. More of proper bleeding lang yan.
Ok na FM ko sir testa.. It was a faulty fuel pump.. Kaya pala minsan erratic idle ko lalo na kung mainit at naka park lang with the aircon on.. Stable na idling RPM and malakas na humatak..
Problem ko naman is nagloloko na yata power steering ko.. Minsan matigas..
Aircon ko din d na gaano malamig..
Matanda na si FM..![]()
Good day! Tanong ko lang kung ano recommended brand ng fuel filter para sa pajero natin kahit yung replacement lang na ok yung quality. First time ko pa lang magpapalit since I acquired my pajero last december. 1994 pajero 4m40 JDM yung rig ko. Thanks
Your FM ain't old man. It just needs a few bits to keep it running. Check your power steering hoses and pump. Maybe you have a leak somewhere.
Your A/C system would also have a series of hoses, valves and fans. Just have them all checked.
My FM is still my favourite all-around vehicle.![]()
