Before the oem filter. Very easy lang install. In and out lang. Kita mo agad kung may tubig or sediments. Hintay ko lang yung order kong isa pang filter. Para sa fm ko.
Salamat sir BG! Actually luma na yang Pirelli's.. Sinubukan ko lang if mabibitin ba ako sa 31x10.5 in case mag lift ako..
Tanong lang ako mga sir.. Maxxis Bighorn MT & Federal Couragia MT, ano pipiliin nyo?
Tsaka anong All-Terrain tires ang pinaka maangas ang itsura pero reasonable ang price?
Salamat sa inputs mga sir!
Thanks crazy_boy. I'll contact him soon. Btw, got another issue with our pajero. When its at idle/heavy traffic during very hot weather, the ac does not get cold anymore but once moving fast, gets back to normal cooling. Had it checked by 2 aircon shops already. Just had it cleaned. The freon is still full after what happened. Any similar experiences or advice? TIA.
Posted via Tsikot Mobile App
^did you check your aux fans? Baka busted na. Ingat sa busted aux fan. Baka mag overheat. If I'm not mistaken, 3 aux fans sa FM. Isang big and 2 small.
Mga gurus, ano tawag sa bumbilya ng compass natin and saan nakakabili nito? Napundi na kasi yung sakin.
sir aside from aux fans (carbon brush), check mo aircon actuator mo near kickdown cable. nag eengage yun dapat (tataas rpm) pag naka park or N. pasilip mo na din kay joseph pag nadaan ka. or kay Ceejays sa las pinas for your aircon. Dun ako nagpapagawa kahit from QC ako. sulit ang biyahe.
Got a similar situation last saturday since nabilad for almost 6 hrs open parking. Nag hi pressure and the cause was the aux fan in front. Wear and tear ng wires nag corode.
Just had my main aux fan repaired. Napapalitan nga carbon brush. P98 yung carbon brush tapos P300 yung labor, medyo matagal din kasi nagawa, mga 3 hrs.
Mahirap yung pagtanggal nang isang piyesa kasi parang mas malaki yung dulo nung center pole at kelangan pa lihain para mahugot yung assembly na kulay brown. Ito yung mahirap bunutin na part.
Thanks for ur replies. Aux fans are all working. I'll plan a trip to Joseph or Ceejays soon. Or are there any other good ac shops near marikina?
This happened to me about a month ago. The small fan was the culprit as it already stopped working. Since it's hard to access and check, I never noticed it. It caused the system's pressure to go up and wrecked a valve. I ended up replacing the motor for the little fan and the valve.
