Nasira yung park light mode ng left stalk switch ko. Ayaw mag on lahat from gauge clusters to tail lights. Sana may naputol na wire lang![]()
I got Mobil1 ATF 220 Dexon 11D sa SM North today. sale for P195 only. Just right for my 40k ATF change, palinis ko na rin filter ko.
Update: May pumutok lang na fuse sa engine bay!
Ang hindi lang namin maayos-ayos ni Jimson yung static ng radio. Kapag medyo mahina ang radio reception at bumusina ako, may nati-trigger na static. Nilagyan na ng choke filter yung HU (+) and condenser, meron pa rin. Is this normal? Bakit wala naman sa Montero![]()
Yeah that's next on my list sir pag may open time. Pwede kayang pasira na yung HU? Its still the stock Alpine. 11 years na![]()
FM peeps,
ano kaya problem if naka close windows naman, pero pagnapadaan sa pollution or mausok na area, hindi naman pumapasok ang usok pero you can smell it.....ano dapat gawen or palitan dito?
dun yan sir pumapasok sa grills dun sa area ng wipers or yung vent sa casing ng evaporator if im not mistaken... parang may flap kasi yun. yung mga aircon shops usually tinatakpan yun as requested by customers.
im not really sure sa solution pero para matesting, magspray ka ng pabango dun sa grills sa wipers, tapos dapat hindi aamoy sa loob. kung umamoy, may singaw nga
Guys, I think this was already asked before but I can't seem to locate the thread.
Just wanted to ask if its totally normal to be able to engaged the transmission from P to R by just pressing the engaged button on the A/T gear lever, even without stepping on the Brake pedals?
I am not able to compare it to other A/T tranmission systems as my only experience with A/T transmission is with my 2005 Altis and my dad's 2005 Starex CRDI....both of which requires for the driver to step on the Brake Pedal first before you can engage P to R.
I was thinking, baka old design lang ng A/T ang ganitong style....Thanks!
normal... ata?!?hehe. ganyan din kasi sa akin.pero for safety, naging reflex ko na ang umapak sa break while engaging the transmission from P to R. para kapag nasa R na, di basta basta aatras ang pajero. although i agree with you yung iba namin kotse kailangan talaga umapak sa break para ma-engage yung transmission, parang may shift lock.
have you ever noticed this problem in your gen 2/ 2.5...
pag morning... (unang start), when you turn the steering wheel to its max. (left or right) you hear a noise coming from the inside,...
has anyone experienced this.
my mechanic check the ff: (but no problem at all)
- steering pump ok.
- a/t fluid ok.
- replace the steering seal ok.
as of now i have no idea kung saan nangagaling yung noise na yun.
calling all gurus![]()
anyone know the stock front ride height? Pina-adjust ko kasi before dahil bagsak yung nguso gusto ko siyang balik sa stock specs. TIA
